Bulk delete Slack messages with smart filtering and confirmations
Created by: Elie Kattar || solutionflows
Elie Kattar
Last update a month ago
Categories
🧹 Jedi Cleaner for Slack
❌ Slack's Limitation
Slack lacks a native bulk delete feature. Users must delete messages manually, which is time-consuming and inefficient for large volumes.
✅ Our Solution
Jedi Cleaner automates Slack message deletion using smart filters, safety confirmations, and enterprise-grade reliability.
🚀 Key Features & Capabilities
⚡ Lightning-Fast Bulk Operations
  • Delete hundreds of messages in minutes
  • Intelligent rate limiting prevents API throttling
  • Auto-retry on failure ensures reliable operation
🎯 Smart Message Filtering
  • Keyword match – Find messages with specific terms
  • User mentions – Target messages that mention specific users
  • Exact phrases – Use quotes for precision
  • Bot/User content – Handle mixed sources seamlessly
🛡️ Enterprise-Grade Safety
  • Confirmation workflow – No accidental deletions
  • Timeout – Requests expire after 5 minutes
  • Preview-first – Review messages before deletion
  • Granular control – Choose exactly what to delete
🔍 Intelligent Search & Preview
  • Flexible filters (words, phrases, patterns)
  • Preview + count before deletion
  • Multi-channel support with context isolation
📊 Complete Workflow Management
  • Auto-cleanup of bot messages after execution
  • Real-time progress tracking
  • Debug logs and audit trail
  • Static data persistence and cleanup
🧪 How It Works
Phase 1: Search Request
User: /cleanup "error messages"
Bot Response:
🔍 Found 15 messages containing "error messages"
📊 Breakdown:
• Will be permanently deleted
• Cannot be undone
• Respond within 5 minutes
✅ Type: @cleaner_jedi yes
❌ Type: @cleaner_jedi cancel
Phase 2: User Confirmation
User: @cleaner_jedi yes
Bot: 🗑️ Deleting 15 messages containing "error messages"
Phase 3: Completion
✅ Cleanup Complete
• 15 messages deleted
• Channel cleaned
• Auto-deletes this message in 5 seconds
🛠️ Technical Architecture
Core Components
  • Unified Webhook Handler
    Handles slash commands & mentions, deduplicates events
  • Search Engine
    Integrates Slack API, parses & filters search terms
  • Safety & Confirmation System
    Temporary storage, expiration logic, user auth
  • Bulk Operations Engine
    Message deletion, progress tracking, error handling
  • Cleanup & Memory Management
    Deletes bot messages, static data cleanup
📱 User Commands
Command Description Example
/cleanup [term] Search messages containing [term] /cleanup "webhook error"
@cleaner_jedi yes Confirm deletion After preview
@cleaner_jedi cancel Cancel pending deletion Cancels active request
🧩 Edge Cases
Scenario Bot Response
No messages found "No messages found containing '[term]'"
Expired confirmation "Request expired. Please run /cleanup again"
No pending request "No pending cleanup found. Run /cleanup first"
Invalid search term "Please provide a valid search term"
⚙️ Setup Requirements
Slack App Configuration
OAuth Scopes:
✅ chat:write
✅ chat:write.public
✅ channels:history
✅ groups:history
✅ app_mentions:read
✅ commands
Event Subscriptions:
✅ app_mention
✅ message.channels
Slash Command:
Command: /cleanup
URL: https://your-n8n.app.cloud/webhook/cleanerjedi
Hint: [search term]
n8n Workflow Setup
Required Nodes:
  • Webhook Trigger – Captures Slack events
  • Respond to Webhook – Handles routing
  • Switch Node – Event type routing
  • Slack API Nodes – Search, delete, notify
  • JavaScript Nodes – Logic & validation
⚡ Advanced Features
🧠 Intelligent Deduplication
eventId = `cmd_${body.command}_${body.user_id}_${body.trigger_id}`;
if (staticData.recentEvents.includes(eventId)) {
  return []; // Skip duplicate
🔍 Flexible Search Terms
  • Single words: test
  • Phrases: "error message"
  • Special characters: webhook-failed
  • Case-insensitive by default
♻️ Auto-Cleanup
setTimeout(() => {
  deleteMessage(completionMessage.ts);
  deleteMessage(progressMessage.ts);
}, 5000);
🧠 Storage Management
  • Temp storage for requests
  • Auto-expiry cleanup
  • Memory-safe event trimming
📊 Error Handling & Logging
Error Scenarios
❌ Invalid term
⏰ Expired request
🚫 Access denied
⚠️ Rate limit hit
Debugging & Monitoring
  • Event IDs, timestamps
  • Key-value storage info
  • API response codes
✅ Usage Examples
Example 1: Delete Error Messages
/cleanup "error"
→ Bot: Found 23 messages
→ @cleaner_jedi yes
→ ✅ Deleted 23 messages
Example 2: Cancel Midway
/cleanup "from:@john"
→ Bot: Found 8 messages
→ @cleaner_jedi cancel
→ ❌ Operation cancelled
Example 3: Search by Date
/cleanup "2024-01-15"
→ Bot: Found 12 messages
→ @cleaner_jedi yes
→ ✅ 12 messages deleted
🔒 Security & Safety
  • User confirmation required
  • 5-minute time limits
  • Permission-aware deletions
  • Audit trail logging
🚀 Performance Optimizations
  • Minimal webhook/API usage
  • Batch deletion
  • Cached recent events
Memory Handling:
  • Temp data cleanup
  • Key expiration
  • Cache trimming
📈 Monitoring & Analytics
Metrics Tracked
  • Messages per operation
  • User response times
  • Failure & error rates
  • Storage performance
Logging
console.log('✅ SUCCESS:', operationDetails);
console.warn('⚠️ WARNING:', warningDetails);
console.error('❌ ERROR:', errorDetails);
console.info('ℹ️ INFO:', informationDetails);
🎉 Summary
For Users
  • ✅ Simple commands
  • ✅ Preview + safety
  • ✅ Fast processing
  • ✅ Clear status feedback
For Admins
  • ✅ Lower API load
  • ✅ Full logging
  • ✅ Resilient to errors
  • ✅ Lightweight memory footprint
For Developers
  • ✅ Modular, clean code
  • ✅ Well-documented
  • ✅ Scalable & robust
  • ✅ Easy to extend
PDF how to do Document Included
