Automated hazard analysis for ISO 26262 compliance using GPT-4
Created by: MRJ || manirajan
MRJ
Last update 2 months ago
Modular Hazard Analysis Workflow : Free Version
Business Value Proposition
Accelerates ISO 26262 compliance for automotive/industrial systems by automating safety analysis while maintaining rigorous audit standards.
:chart_with_upwards_trend: Key Benefits
  • Time
    • Instant report generation vs. weeks of documentation for HAZOP
  • Risk Mitigation
    • Pre-validated templates reduce human error
Quick guide
  • Input a systems_description file to the workflow
  • Provide an OPENAI_API_KEY to the chat model. You can also replace the chat model with the model of your interest.
:play_or_pause_button: Running the Workflow
Refer to the github repo to understand in detail about how the workflow can be used
:email: Contact
For collaboration proposals or security issues, contact me by Email.
:warning: Validation & Limitations
AI-Assisted Analysis Considerations
Advantage Mitigation Strategy Implementation Example
Rapid hazard identification Human validation layer Manual review nodes in workflow
Consistent S/E/C scoring Rule-based validation ASIL-D → Redundancy check
Edge case coverage Cross-reference with historical data Integration with incident databases
