Automated Telegram UserBot session monitoring & recovery with TelePilot
Created by: IvanCore || ivancore
IvanCore
Last update 25 days ago
Categories
Disclaimer: This workflow contains community nodes that are only compatible with the self-hosted version of n8n.
Important distinction: This template manages Telegram Copilot's UserBots (client accounts), not Telegram Bots.
UserBot vs. Bot: Key Differences
🔹 Telegram Copilot's UserBots
  • Authenticate as real user accounts (phone number required)
  • Can join groups/channels without "Bot" label
  • Subject to Telegram's client API limits
  • Require manual login (MFA supported)
🔹 Telegram Bots
  • Use @BotFather-created tokens
  • Limited to bot API functionality
  • Can't initiate chats with unbidden users
  • No phone number required
    This template solves the unique challenges of UserBot management through:
Core Functionality
🛡️ Session Reliability
  • Automatic crash recovery (5-step restart sequence)
  • Persistent session monitoring (checks every 6h)
  • Database cleanup via /clear command
📱 Multi-Device Support
  • Manages sessions independently from mobile clients
  • Tracks active devices via /stat command
  • Isolates session data per credential
🔔 Smart Notifications
  • Real-time alerts to admin chat
  • Detailed error context with authState snapshots
  • Success confirmations with session metadata
Setup Guide
Prerequisites
  • Self-hosted n8n instance (community node required)
  • Valid Telegram account for UserBot
  • Telegram bot token for notifications
  • TelePilot credentials with api_id/api_hash
Configuration Steps
Credential Setup
  • Add TelePilot credentials in n8n
  • Configure Telegram bot token in notification nodes
  • Set admin chat ID for alerts
Monitoring Customization
  • Adjust check frequency in Schedule Trigger
  • Modify alert thresholds in Filter nodes
  • Configure retry logic in recovery sequence
Session Management
  • Test /start command flow
  • Verify /stat output format
  • Confirm notification delivery
Workflow Customization
Advanced Options
  • Add secondary notification channels (Email, Slack)
  • Implement escalating alert system
  • Integrate with monitoring dashboards
  • Customize recovery attempt limits
Compliance Notes
  • UserBots must comply with Telegram's Terms of Service
  • Not intended for bulk messaging or spam
  • Recommended for legitimate automation use cases
Note: UserBots must comply with Telegram ToS. Not for spam/mass messaging.
Why This Matters: UserBots enable automation scenarios impossible with regular bots (e.g., group management as normal user, reacting as human account). This workflow keeps them reliably online 24/7.
