Transcribe & summarize audio with Whisper and GPT, from Google Drive to Notion
Created by: Abdullah || abdullahmil
Abdullah
Last update 22 days ago
This workflow contains community nodes that are only compatible with the self-hosted version of n8n.
Overview
This workflow automates the process of transcribing audio files and summarizing them using OpenAI models, with the final output stored neatly in Notion. Whether you're a researcher, content creator, student, or professional, this automation saves time by converting voice recordings into actionable summaries with zero manual effort.
Created by: Abdullah Dilshad
Contact: [email protected]
Who It’s For
This template is ideal for:
  • Researchers: Transcribe and summarize interviews, lectures, or research recordings.
  • Content Creators: Convert podcasts or videos into transcripts and social captions/show notes.
  • Students: Automatically turn lectures or study group audio into summarized notes.
  • Professionals: Log meeting notes and summaries directly into your Notion workspace.
How It Works
This four-step workflow performs the following:
  • Step 1: Trigger: New Audio in Google Drive
    Automatically triggers when a new audio file (MP3/WAV) is uploaded to a specified Google Drive folder.The file is then downloaded for processing.
  • Step 2: Transcribe Audio with Whisper
    The audio file is sent to OpenAI’s Whisper model for high-accuracy transcription.
  • Step 3: Summarize Transcript with GPT-4
    The transcript is passed to GPT-4, which generates a clean, concise summary.
  • Step 4: Store Summary in Notion
    A new Notion page is created with the generated summary and optional metadata (file name, upload time, etc.).
Setup Instructions
  • Step 1: Google Drive Trigger
    Connect your Google Drive account.
    Select the folder you want to monitor.
    This node detects new file uploads and passes the file for download.
  • Step 2: Download File
    Downloads the new audio file for transcription.
    Step 3: Transcribe Recording (OpenAI Whisper)
    Connect your OpenAI API Key.
    Ensure this node receives the binary audio file.
    It will return the transcription as plain text.
  • Step 3: Transcribe Recording (OpenAI Whisper)
  • Step 4: Summarize Transcript (GPT-4 via AI Agent)
    Use your OpenAI API Key.
    Configure a summarization prompt like:
    "Summarize the following transcript in a clear and concise manner:"
    Connect the output from Whisper into this GPT-4 prompt.
  • Step 5: Notion Integration
    Connect your Notion account.
    Choose or create a database to store summaries.
    Map the GPT output (summary) to a "Text" or "Rich Text" property.
    Optionally include metadata like filename, file upload date, etc.
