Automate ISO 26262 compliance with GPT-4 for automotive safety analysis
Created by: MRJ || manirajan
MRJ
Last update 25 days ago
:car: Business Value Proposition
Accelerates ISO 26262 compliance for automotive/industrial systems by automating safety analysis while maintaining rigorous audit standards.
:gear: How It Works
graph TD
    A[Engineer uploads<br>system description] --> B(LLM identifies hazards)
    B --> C(LLM scores risks per ISO 26262)
    C --> D(Generates mitigation strategies)
    D --> E(Produces audit-ready reports)
:chart_with_upwards_trend: Key Benefits
  • Time
    • 50-70% faster than manual HAZOP/FMEA sessions
    • Instant report generation vs. weeks of documentation
  • Risk Mitigation
    • Pre-validated templates reduce human error
    • Auto-generated traceability simplifies audits
:warning: Governance Controls
  • Human-in-the-loop: All LLM outputs require engineer sign-off
  • Version tracking: Full history of modifications
  • Audit mode: Export all decision rationales
:computer: Technical Requirements
  • Runs on existing n8n instances
  • Docker deployment (<1hr setup)
  • Integrates with JAMA/DOORS (optional)
:wrench: Setup and Usage
Prerequisites
Enterprise-ready deployment: When supported by IT infrastructure teams, this solution transforms into a scalable AI safety assistant, providing real-time HARA guidance akin to engineering Co-pilot tools.
:arrow_down: Installation and :play_or_pause_button: Running the Workflow
For installation procedures and usage of workflow, refer the repository
:warning: Validation & Limitations
AI-Assisted Analysis Considerations
Advantage Mitigation Strategy Implementation Example
Rapid hazard identification Human validation layer Manual review nodes in workflow
Consistent S/E/C scoring Rule-based validation ASIL-D → Redundancy check
Edge case coverage Cross-reference with historical data Integration with incident databases
Critical Validation Steps
  1. AI Output Review node in n8n
    Example: (by code)
      "type": "function",
      "parameters": {
        "functionCode": "if ($input.item.json.ASIL === 'D' && !$input.item.json.redundancy) throw new Error('ASIL D requires redundancy');"
  2. Version Control
  • Prompt versions tied to ISO standard editions (e.g., ISO26262:2018-v1.2)
  • Git-tracked changes to ai_models/training_data/
  1. Audit trails
  • Providing a log structure for audit trails
# Log structure
/logs/
└── YYYY-MM-DD/
  ├── hazards_approved.log
  └── hazards_rejected.log
