Build a document QA system with Google Drive, Pinecone, and OpenAI RAG
Created by: Abdullahi Osman || abdosman06
Abdullahi Osman
Last update a month ago
Title
RAG AI Agent for Documents in Google Drive → Pinecone → OpenAI Chat (n8n workflow)
Short Description
This n8n workflow implements a Retrieval-Augmented Generation (RAG) pipeline + AI agent, allowing users to drop documents into a Google Drive folder and then ask questions about them via a chatbot. New files are indexed automatically to a Pinecone vector store using OpenAI embeddings; the AI agent loads relevant chunks at query time and answers using context plus memory.
Why this workflow matters / what problem it solves
  • Large language models (LLMs) are powerful, but they lack up-to-date, domain-specific knowledge.
  • RAG augments the LLM with relevant external documents, reducing hallucination and enabling precise answers. (Pinecone)
  • This workflow automates the ingestion, embedding, storage, retrieval, and chat logic — with minimal manual work.
  • It’s modular: you can swap data sources, vector DBs, or LLMs (with some adjustments).
  • It leverages the built-in AI Agent node in n8n to tie all the parts together. (n8n)
How to get the required credentials
Service Purpose in Workflow Setup Link What you need / steps
Google Drive (OAuth2) Trigger new file events & download the file https://docs.n8n.io/integrations/builtin/credentials/google/oauth-generic/ Create a Google Cloud OAuth app, grant it Drive scopes, get client ID & secret, configure redirect URI, paste into n8n credentials.
Pinecone Vector database for embeddings https://docs.n8n.io/integrations/builtin/credentials/pinecone/ Sign up at Pinecone, in dashboard create an index, get API key + environment, paste into n8n credential.
OpenAI Embeddings + chat model https://docs.n8n.io/integrations/builtin/credentials/openai/ Log in to OpenAI, generate a secret API key, paste into n8n credentials.
You’ll configure these under n8n → Credentials → New Credential, matching credential names referenced in your workflow nodes.
Detailed Walkthrough: How the Workflow Works
Here’s a step-by-step of what happens inside your workflow (matching your JSON):
1. Google Drive Trigger
  • Watches a specified folder in Google Drive. Whenever a new file appears (fileCreated event), the workflow is triggered (polling every minute).
  • You must set the folder ID (in “folderToWatch”) to the Drive folder you want to monitor.
2. Download File
  • Takes the file ID from the trigger and downloads the file content (binary).
3. Indexing Path: Embeddings + Storage
(This path only runs when new files arrive)
  • The file is sent to the Default Data Loader node (via the Recursive Character Text Splitter) to break it into chunks with overlap (so context is preserved).
  • Each chunk is fed into Embeddings OpenAI to convert text into embedding vectors.
  • Then Pinecone Vector Store (insert mode) ingests the vector + text metadata into your Pinecone index.
  • This ensures your vector store stays up-to-date with files you drop into Drive.
4. Chat / Query Path
(Triggered by user chat via webhook)
  • When a chat message arrives via When Chat Message Received, it gets passed into the AI Agent node.
  • Before generation, the AI Agent calls the Pinecone Vector Store1 set in “retrieve-as-tool” mode, which runs a vector-based retrieval using the user query embedding. The relevant text chunks are pulled as tools/context.
  • The OpenAI Chat Model node is linked as the language model for the agent.
  • Simple Memory node provides conversational memory (keeping history across messages).
  • The agent combines retrieved context + memory + user input and instructs the model to produce a response.
5. Connections / Flow Logic
  • The Embeddings OpenAI node’s output is wired into Pinecone Vector Store (insert) and also into Pinecone Vector Store1 (so the same embeddings can be used for retrieval).
  • The AI Agent has tool access to Pinecone retrieval and memory.
  • The Download File node triggers the insert path.
  • The When chat message triggers the agent path.
Similar Workflows / Inspirations & Comparisons
To help understand how your workflow fits into what’s already out there, here are a few analogues:
  • n8n Blog: “Build a custom knowledge RAG chatbot” — they show a workflow that ingests documents from external sources, indexes them in Pinecone, and responds to queries via n8n + LLM. (n8n Blog)
  • Index Documents from Google Drive to Pinecone — this is nearly identical for the ingestion part: trigger on Drive, split, embed, upload. (n8n)
  • Build & Query RAG System with Google Drive, OpenAI, Pinecone — shows the full RAG + chat logic, same pattern. (n8n)
  • Chat with GitHub API Documentation (RAG) — demonstrates converting API spec into chunks, embedding, retrieving, and chatting. (n8n)
  • Community tutorials & forums talk about using the AI Agent node with tools like Pinecone, and how the RAG part is often built as a sub-workflow feeding an agent. (n8n Community)
What sets your workflow apart is your explicit combination: Google Drive → automatic ingestion → chat agent with tool integration + memory. Many templates show either ingestion or chat, but fewer show them combined cleanly with n8n’s AI Agent.
Suggested Published Description (you can paste/adjust)
RAG AI Agent for Google Drive Documents (n8n workflow)
This workflow turns a Google Drive folder into a live, queryable knowledge base. Drop PDF, docx, or text files into the folder → new documents are automatically indexed into a Pinecone vector store using OpenAI embeddings → you can ask questions via a webhook chat interface and the AI agent will retrieve relevant text, combine it with memory, and answer in context.
Credentials needed
  1. Drive trigger picks up new files
  2. Download, split, embed, insert into Pinecone
  3. Chat webhook triggers AI Agent
  4. Agent retrieves relevant chunks + memory
  5. Agent uses OpenAI model to craft answer
This is built on the core RAG pattern (ingest → retrieve → generate) and enhanced by n8n’s AI Agent node for clean tool integration.
Inspiration & context
This approach follows best practices from existing n8n RAG tutorials and templates, such as the “Index Documents from Google Drive to Pinecone” ingestion workflow and “Build & Query RAG System” templates. (n8n)
You're free to swap out the data source (e.g. Dropbox, S3) or vector DB (e.g. Qdrant) as long as you adjust the relevant nodes.
If you like, I can generate a polished Markdown README for you (with badges, diagrams, instructions) ready for GitHub/n8n community publishing. Do you want me to build that?
