Be first. Be relevant. Get hired.
This ready-to-import n8n workflow automates your entire Freelancer.com job search:
it scans new listings, filters the best ones with AI, writes proposal drafts, and sends them to Telegram instantly — all while logging every opportunity into Google Sheets.
💡 Why Freelancers Love It
- ⚡ Instant Alerts: Get notified within minutes of new high-quality jobs.
- 🧠 AI-Powered Scoring: Filters scams, vague clients, and low-value gigs automatically.
- ✍️ Smart Proposal Drafts: GPT-4.1 crafts 150–200 word personalized proposals for you.
- 📱 Telegram Integration: See job details + AI proposal in one alert message.
- 📊 Auto Tracking: Logs every lead in Google Sheets with scores, notes, and timestamps.
Spend less time searching — and more time winning projects.
🧩 What’s Included
- ✅ n8n Workflow (.json) — ready to import and launch
- ✅ Setup Guide (Markdown) — complete 5-step configuration walkthrough
🧰 Requirements
- Free n8n Cloud account (or self-hosted instance)
- OpenAI API key (GPT-4.1 or GPT-4-mini)
- Telegram bot + Chat ID (takes 2 minutes to create)
- Google Sheets account
🪜 5-Step Setup Guide (Detailed)
1️⃣ Prepare Your Tools
- Get your OpenAI key → platform.openai.com
- Create a Telegram bot via @BotFather → copy your token
- Use @userinfobot to get your Chat ID
- Create a Google Sheet with headers:
Timestamp | Job | Description | Link | AI Score | Reasoning | Red Flags | Client Type | AI Proposal | Alert Timestamp
- Keep all keys and URLs ready.
2️⃣ Import the Workflow in n8n
- Open n8n → + Workflow → Import from File → choose the
.json
provided below.
- Once imported, open these nodes and connect your credentials:
- OpenAI nodes → add your API key
- Google Sheets nodes → sign in with Google
- Telegram node → paste your bot token + chat ID
- Confirm the Schedule Trigger runs every 5 minutes (default).
3️⃣ Personalize Your Keywords & Filters
4️⃣ Test Your Automation
- Click Execute Workflow once.
- If everything is set:
- 🟢 Nodes turn green (success)
- 📩 Telegram shows your first job alert
- 📊 Google Sheet updates with a new job entry
- If empty, try:
- Broader keyword (e.g.,
python
instead of python scraper
- Increase freshness (2 → 6 hours)
5️⃣ Go Live & Expand
- Activate your workflow.
- Let it run for 24–48 hours, then refine:
- Raise score threshold to 8–9 for higher quality
- Add RSS nodes for new categories (design, dev, content)
- Extend alerts to Slack, Discord, or Email
- Replace Google Sheets with Airtable or Notion
- Pro Tip: Use Apify to scrape Upwork, Fiverr, or niche job boards → feed results into the same analyzer chain.
⚙️ How It Works (Behind the Scenes)
Schedule → Fetch RSS → Filter → AI Analyze (score 1–10)
→ If score ≥ 7 → AI Proposal → Log to Sheets → Send Telegram Alert
You still review and apply manually (TOS-safe), but you’ll always be among the first 5 applicants.
🔌 Future-Proof Extensions
Extension |
Description |
Apify Integration |
Scrape Upwork, Fiverr, or niche boards with structured data |
Multi-Channel Alerts |
Add Slack, Discord, or email digests |
Team Routing |
Send design jobs to one chat, dev jobs to another |
Advanced Scoring |
Add client history or location weighting |
Database Sync |
Replace Sheets with Notion, Airtable, or PostgreSQL |
🧾 Terms & Notes
- Manual review required (no auto-apply)
- API costs: OpenAI ~$5–10/month
- Respects Freelancer.com Terms of Service
- All keys stored securely inside n8n credentials
🏁 Summary
Automate your freelancing workflow.
This system finds, filters, and drafts proposals for you while you sleep.
⚙️ Plug it into n8n → 🔑 Add keys → 🎯 Go live → 💰 Start winning faster.
