Transform database design from weeks to minutes with this intelligent multi-agent system. Perfect for agencies, consultancies, and SaaS companies offering database architecture as a lead magnet or service.
🤖 4 Specialized AI Agents:
🔄 Smart Quality Loop:
Automatically retries up to 3 times if score falls below B grade, feeding previous feedback to improve the design iteratively.
✨ What You Get:
💼 Perfect For:
🎯 Use as Lead Magnet:
Offer free database blueprints to capture leads, then upsell implementation, custom automations, and ongoing optimization services.
⚙️ Technical Highlights:
Agency Lead Magnet
Capture leads by offering free database architecture reviews and blueprints
Rapid Prototyping
Quickly generate database schemas for MVP development and validation
Legacy System Modernization
Help companies redesign outdated database structures with modern best practices
Technical Consulting
Provide instant database assessments and recommendations to clients
Educational Tool
Teach database design principles through AI-generated examples and feedback
Pre-Sales Tool
Demonstrate technical expertise to prospects before engagement
✅ Multi-agent AI collaboration with specialized roles
✅ Automatic quality control and iterative improvement (max 3 retries)
✅ Support for PostgreSQL, MySQL, MSSQL, MariaDB
✅ Production-ready SQL script generation
✅ Comprehensive scoring system (Schema/Performance/Scalability/Security)
✅ Optional automatic SQL execution
✅ Detailed feedback with actionable recommendations
✅ Customizable form fields for different industries
✅ Error handling and graceful failures
✅ Complete audit trail of all agent decisions
PREREQUISITES:
CONFIGURATION STEPS:
Import the workflow JSON into your n8n instance
Configure Anthropic API credentials:
(Optional) Configure database connection:
Customize the form (optional):
Test the workflow:
Customize agent prompts (optional):
Deploy:
COST CONSIDERATIONS:
REQUIRED:
OPTIONAL:
#ai-agents #database-design #postgresql #mysql #lead-generation #automation #langchain #claude #schema-design #multi-agent #consulting-tool #saas-tool #development #code-generation #sql-generator
📖 Website: https://evervise.com/
💬 See More Products: https://store.evervise.com/
✨ Support: [email protected]
