Monitor emails & send AI-generated auto-replies with Ollama & Telegram alerts
Created by: Vigh Sandor || vighsandor
Vigh Sandor
Last update 24 days ago
Workflow Overview
This advanced n8n workflow provides intelligent email automation with AI-generated responses. It combines four core functions:
  1. Monitors incoming emails via IMAP (e.g., SOGo)
  2. Sends instant Telegram notifications for all new emails
  3. Uses AI (Ollama LLM) to generate contextual, personalized auto-replies
  4. Sends confirmation notifications when auto-replies are sent
Unlike traditional auto-responders, this workflow analyzes email content and creates unique, relevant responses for each message.
Setup Instructions
Prerequisites
Before setting up this workflow, ensure you have:
  • An n8n instance (self-hosted or cloud) with AI/LangChain nodes enabled
  • IMAP email account credentials (e.g., SOGo, Gmail, Outlook)
  • SMTP server access for sending emails
  • Telegram Bot API credentials
  • Telegram Chat ID where notifications will be sent
  • Ollama installed locally or accessible via network (for AI model)
  • The llama3.1 model downloaded in Ollama
Step 1: Install and Configure Ollama
Local Installation
  1. Install Ollama on your system:
    • Visit https://ollama.ai and download the installer for your OS
    • Follow installation instructions for your platform
  2. Download the llama3.1 model:
    ollama pull llama3.1
  3. Verify the model is available:
    ollama list
  4. Start Ollama service (if not already running):
    ollama serve
  5. Test the model:
    ollama run llama3.1 "Hello, world!"
Remote Ollama Instance
If using a remote Ollama server:
  • Note the server URL (e.g., http://192.168.1.100:11434)
  • Ensure network connectivity between n8n and Ollama server
  • Verify firewall allows connections on port 11434
Step 2: Configure IMAP Credentials
  1. Navigate to n8n Credentials section
  2. Create a new IMAP credential with the following information:
    • Host: Your IMAP server address
    • Port: Usually 993 for SSL/TLS
    • Username: Your email address
    • Password: Your email password or app-specific password
    • Enable SSL/TLS: Yes (recommended)
    • Security: Use STARTTLS or SSL/TLS
Step 3: Configure SMTP Credentials
  1. Create a new SMTP credential in n8n
  2. Enter the following details:
    • Host: Your SMTP server address (e.g., Postfix server)
    • Port: Usually 587 (STARTTLS) or 465 (SSL)
    • Secure connection: Enable based on your server configuration
    • Allow unauthorized certificates: Enable if using self-signed certificates
Step 4: Configure Telegram Bot
  1. Create a Telegram bot via BotFather:
    • Open Telegram and search for @BotFather
    • Send /newbot command
    • Follow instructions to create your bot
    • Save the API token provided by BotFather
  2. Obtain your Chat ID:
    • Method 1: Send a message to your bot, then visit:
      https://api.telegram.org/bot<YOUR_BOT_TOKEN>/getUpdates
    • Method 2: Use a Telegram Chat ID bot like @userinfobot
    • Method 3: For group chats, add the bot to the group and check the updates
    • Note: Group chat IDs are negative numbers (e.g., -1234567890123)
  3. Add Telegram API credential in n8n:
    • Credential Type: Telegram API
    • Access Token: Your bot token from BotFather
Step 5: Configure Ollama API Credential
  1. In n8n Credentials section, create a new Ollama API credential
  2. Configure based on your setup:
    • For local Ollama: Base URL is usually http://localhost:11434
    • For remote Ollama: Enter the server URL (e.g., http://192.168.1.100:11434)
  3. Test the connection to ensure n8n can reach Ollama
Step 6: Import and Configure Workflow
  1. Import the workflow JSON into your n8n instance
  2. Update the following nodes with your specific information:
Check Incoming Emails Node
  • Verify IMAP credentials are connected
  • Configure polling interval (optional):
    • Default behavior checks on workflow trigger schedule
    • Can be set to check every N minutes
  • Set mailbox folder if needed (default is INBOX)
Send Notification from Incoming Email Node
  • Update chatId parameter with your Telegram Chat ID
  • Replace -1234567890123 with your actual chat ID
  • Customize notification message template if desired
  • Current format includes: Sender, Subject, Date-Time
Dedicate Filtering As No-Response Node
  • Review spam filter conditions:
    • Blocks emails from addresses containing "noreply" or "no-reply"
    • Blocks emails with "newsletter" in subject line (case-insensitive)
  • Add additional filtering rules as needed:
    • Block specific domains
    • Filter by keywords
    • Whitelist/blacklist specific senders
Ollama Model Node
  • Verify Ollama API credential is connected
  • Confirm model name: llama3.1:bf230501 (or adjust to your installed version)
  • Context window set to 4096 tokens (sufficient for most emails)
  • Can be adjusted based on your needs and hardware capabilities
Basic LLM Chain Node
  • Review the AI prompt engineering (pre-configured but customizable)
  • Current prompt instructs the AI to:
    • Read the email content
    • Identify main topic in 2-4 words
    • Generate a professional acknowledgment response
    • Keep responses consistent and concise
  • Modify prompt if you want different response styles
Send Auto-Response in SMTP Node
  • Verify SMTP credentials are connected
  • Check fromEmail uses correct email address:
    • Currently set to {{ $('Check Incoming Emails - IMAP (example: SOGo)').item.json.to }}
    • This automatically uses the recipient address (your mailbox)
  • Subject automatically includes "Re: " prefix with original subject
  • Message text comes from AI-generated content
Send Notification from Response Node
  • Update chatId parameter (same as first notification node)
  • This sends confirmation that auto-reply was sent
  • Includes original email details and the AI-generated response text
Step 7: Test the Workflow
  1. Perform initial configuration test:
    • Test Ollama connectivity: curl http://localhost:11434/api/tags
    • Verify all credentials are properly configured
    • Check n8n has access to required network endpoints
  2. Execute a test run:
    • Click "Execute Workflow" button in n8n
    • Send a test email to your monitored inbox
    • Use a clear subject and body for better AI response
  3. Verify workflow execution:
    • First Telegram notification received (incoming email alert)
    • AI processes the email content
    • Auto-reply is sent to the original sender
    • Second Telegram notification received (confirmation with AI response)
    • Check n8n execution log for any errors
  4. Verify email delivery:
    • Check if auto-reply arrived at sender's inbox
    • Verify it's not marked as spam
    • Review AI-generated content for appropriateness
Step 8: Fine-Tune AI Responses
  1. Send various types of test emails:
    • Different topics (inquiry, complaint, information request)
    • Various email lengths (short, medium, long)
    • Different languages if applicable
  2. Review AI-generated responses:
    • Check if topic identification is accurate
    • Verify response appropriateness
    • Ensure tone is professional
  3. Adjust the prompt if needed:
    • Modify topic word count (currently 2-4 words)
    • Change response template
    • Add language-specific instructions
    • Include custom sign-offs or branding
Step 9: Activate the Workflow
  1. Once testing is successful and AI responses are satisfactory:
    • Toggle the workflow to "Active" state
    • The workflow will now run automatically on the configured schedule
  2. Monitor initial production runs:
    • Review first few auto-replies carefully
    • Check Telegram notifications for any issues
    • Verify SMTP delivery rates
  3. Set up monitoring:
    • Enable n8n workflow error notifications
    • Monitor Ollama resource usage
    • Check email server logs periodically
How to Use
Normal Operation
Once activated, the workflow operates fully automatically:
  1. Email Monitoring: The workflow continuously checks your IMAP inbox for new messages based on the configured polling interval or trigger schedule.
  2. Immediate Incoming Notification: When a new email arrives, you receive an instant Telegram notification containing:
    • Sender's email address
    • Email subject line
    • Date and time received
    • Note indicating it's from IMAP mailbox
  3. Intelligent Filtering: The workflow evaluates each email against spam filter criteria:
    • Emails from "noreply" or "no-reply" addresses are filtered out
    • Emails with "newsletter" in the subject line are filtered out
    • Filtered emails receive notification but no auto-reply
    • Legitimate emails proceed to AI response generation
  4. AI Response Generation: For emails that pass the filter:
    • The AI reads the full email content
    • Analyzes the main topic or purpose
    • Generates a personalized acknowledgment
    • Creates a professional response that:
      • Thanks the sender
      • References the specific topic
      • Promises a personal follow-up
      • Maintains professional tone
  5. Automatic Reply Delivery: The AI-generated response is sent via SMTP to the original sender with:
    • Subject line: "Re: [Original Subject]"
    • From address: Your monitored mailbox
    • Body: AI-generated contextual message
  6. Response Confirmation: After the auto-reply is sent, you receive a second Telegram notification showing:
    • Original email details (sender, subject, date)
    • The complete AI-generated response text
    • Confirmation of successful delivery
Understanding AI Response Generation
The AI analyzes emails intelligently:
Example 1: Business Inquiry
Incoming Email: "I'm interested in your consulting services for our Q4 project..."
AI Topic Identification: "consulting services"
Generated Response: "Dear Correspondent! Thank you for your message regarding consulting services. I will respond with a personal message as soon as possible. Have a nice day!"
Example 2: Technical Support
Incoming Email: "We're experiencing issues with the API integration..."
AI Topic Identification: "API integration issues"
Generated Response: "Dear Correspondent! Thank you for your message regarding API integration issues. I will respond with a personal message as soon as possible. Have a nice day!"
Example 3: General Question
Incoming Email: "Could you provide more information about pricing?"
AI Topic Identification: "pricing information"
Generated Response: "Dear Correspondent! Thank you for your message regarding pricing information. I will respond with a personal message as soon as possible. Have a nice day!"
Customizing Filter Rules
To modify which emails receive AI-generated auto-replies:
  1. Open the "Dedicate Filtering As No-Response" node
  2. Modify existing conditions or add new ones:
Block specific domains:
{{ $json.from.value[0].address }}
Operation: does not contain
Value: @spam-domain.com
Whitelist VIP senders (only respond to specific people):
Operation: contains
Value: @important-client.com
Filter by subject keywords:
{{ $json.subject.toLowerCase() }}
Value: unsubscribe
Combine multiple conditions:
  • Use AND logic (all must be true) for stricter filtering
  • Use OR logic (any can be true) for more permissive filtering
Customizing AI Prompt
To change how the AI generates responses:
  1. Open the "Basic LLM Chain" node
  2. Modify the prompt text in the "text" parameter
  3. Current structure:
    • Context setting (read email, identify topic)
    • Output format specification
    • Rules for AI behavior
Example modifications:
Add company branding:
Return only this response, filling in the [TOPIC]:
Dear Correspondent!
Thank you for reaching out to [Your Company Name] regarding [TOPIC].
Best regards,
[Your Name]
[Your Company Name]
Make it more casual:
Hi there!
Thanks for your email about [TOPIC].
I'll get back to you personally soon.
Cheers!
Add urgency classification:
Read the email and classify urgency (Low/Medium/High).
Identify the main topic.
Return:
Dear Correspondent!
Thank you for your message regarding [TOPIC].
Priority: [URGENCY]
Customizing Telegram Notifications
Incoming Email Notification:
  1. Open "Send Notification from Incoming Email" node
  2. Modify the "text" parameter
  3. Available variables:
    • {{ $json.from }} - Full sender info
    • {{ $json.from.value[0].address }} - Sender email only
    • {{ $json.from.value[0].name }} - Sender name (if available)
    • {{ $json.subject }} - Email subject
    • {{ $json.date }} - Date received
    • {{ $json.textPlain }} - Email body (use cautiously for privacy)
    • {{ $json.to }} - Recipient address
Response Confirmation Notification:
  1. Open "Send Notification from Response" node
  2. Modify to include additional information
  3. Reference AI response: {{ $('Basic LLM Chain').item.json.text }}
Monitoring and Maintenance
Daily Monitoring
  • Check Telegram Notifications: Review incoming email alerts and response confirmations
  • Verify AI Quality: Spot-check AI-generated responses for appropriateness
  • Email Delivery: Confirm auto-replies are being delivered (not caught in spam)
Weekly Maintenance
  • Review Execution Logs: Check n8n execution history for errors or warnings
  • Ollama Performance: Monitor resource usage (CPU, RAM, disk space)
  • Filter Effectiveness: Assess if spam filters are working correctly
  • Response Quality: Review multiple AI responses for consistency
Monthly Maintenance
  • Update Ollama Model: Check for new llama3.1 versions or alternative models
  • Prompt Optimization: Refine AI prompt based on response quality observations
  • Credential Rotation: Update passwords and API tokens for security
  • Backup Configuration: Export workflow and credentials (securely)
Advanced Usage
Multi-Language Support
If you receive emails in multiple languages:
  1. Modify the AI prompt to detect language:
Detect the email language.
Generate response in the SAME language as the email.
If English: [English template]
If Hungarian: [Hungarian template]
If German: [German template]
  1. Or use language-specific conditions in the filtering node
Priority-Based Responses
Generate different responses based on sender importance:
  1. Add an IF node after filtering to check sender domain
  2. Route VIP emails to a different LLM chain with priority messaging
  3. Standard emails use the normal AI chain
Response Logging
To maintain a record of all AI interactions:
  1. Add a database node (PostgreSQL, MySQL, etc.) after the auto-reply node
  2. Store: timestamp, sender, subject, AI response, delivery status
  3. Use for compliance, analytics, or training data
A/B Testing AI Prompts
Test different prompt variations:
  1. Create multiple LLM Chain nodes with different prompts
  2. Use a randomizer or round-robin approach
  3. Compare response quality and user feedback
  4. Optimize based on results
Troubleshooting
Notifications Not Received
Problem: Telegram notifications not appearing
Solutions:
  • Verify Chat ID is correct (positive for personal chats, negative for groups)
  • Check if bot has permissions to send messages
  • Ensure bot wasn't blocked or removed from group
  • Test Telegram API credential independently
  • Review n8n execution logs for Telegram API errors
AI Responses Not Generated
Problem: Auto-replies sent but content is empty or error messages
Solutions:
  • Check Ollama service is running: ollama list
  • Verify llama3.1 model is downloaded: ollama list
  • Test Ollama directly: ollama run llama3.1 "Test message"
  • Review Ollama API credential URL in n8n
  • Check network connectivity between n8n and Ollama
  • Increase context window if emails are very long
  • Monitor Ollama logs for errors
Poor Quality AI Responses
Problem: AI generates irrelevant or inappropriate responses
Solutions:
  • Review and refine the prompt engineering
  • Add more specific rules and constraints
  • Provide examples in the prompt of good vs bad responses
  • Adjust topic word count (increase from 2-4 to 3-6 words)
  • Test with different Ollama models (e.g., llama3.1:70b for better quality)
  • Ensure email content is being passed correctly to AI
Auto-Replies Not Sent
Problem: Workflow executes but emails not delivered
Solutions:
  • Verify SMTP credentials and server connectivity
  • Check fromEmail address is correct
  • Review SMTP server logs for errors
  • Test SMTP sending independently
  • Ensure "Allow unauthorized certificates" is enabled if needed
  • Check if emails are being filtered by spam filters
  • Verify SPF/DKIM records for your domain
High Resource Usage
Problem: Ollama consuming excessive CPU/RAM
Solutions:
  • Reduce context window size (from 4096 to 2048)
  • Use a smaller model variant (llama3.1:8b instead of default)
  • Limit concurrent workflow executions in n8n
  • Add delay/throttling between email processing
  • Consider using a remote Ollama instance with better hardware
  • Monitor email volume and processing time
IMAP Connection Failures
Problem: Workflow can't connect to email server
Solutions:
  • Verify IMAP credentials are correct
  • Check if IMAP is enabled on email account
  • Ensure SSL/TLS settings match server requirements
  • For Gmail: enable "Less secure app access" or use App Passwords
  • Check firewall allows outbound connections on IMAP port (993)
  • Test IMAP connection using email client (Thunderbird, Outlook)
Workflow Not Triggering
Problem: Workflow doesn't execute automatically
Solutions:
  • Verify workflow is in "Active" state
  • Check trigger node configuration and schedule
  • Review n8n system logs for scheduler issues
  • Ensure n8n instance has sufficient resources
  • Test manual execution to isolate trigger issues
  • Check if n8n workflow execution queue is backed up
Workflow Architecture
Node Descriptions
  1. Check Incoming Emails - IMAP: Polls email server at regular intervals to retrieve new messages from the configured mailbox.
  2. Send Notification from Incoming Email: Immediately sends formatted notification to Telegram for every new email detected, regardless of spam status.
  3. Dedicate Filtering As No-Response: Evaluates emails against spam filter criteria to determine if AI processing should occur.
  4. No Operation: Placeholder node for filtered emails that should not receive an auto-reply (spam, newsletters, automated messages).
  5. Ollama Model: Provides the AI language model (llama3.1) used for natural language processing and response generation.
  6. Basic LLM Chain: Executes the AI prompt against the email content to generate contextual auto-reply text.
  7. Send Auto-Response in SMTP: Sends the AI-generated acknowledgment email back to the original sender via SMTP server.
  8. Send Notification from Response: Sends confirmation to Telegram showing the auto-reply was successfully sent, including the AI-generated content.
AI Processing Pipeline
  1. Email Content Extraction: Email body text is extracted from IMAP data
  2. Context Loading: Email content is passed to LLM with prompt instructions
  3. Topic Analysis: AI identifies main subject or purpose in 2-4 words
  4. Template Population: AI fills response template with identified topic
  5. Output Formatting: Response is formatted and cleaned for email delivery
  6. Quality Assurance: n8n validates response before sending
