Monitor Instagram competitor trends with Claude 3.5 & multi-channel alerts
Last update a month ago
This enterprise-grade n8n workflow automates competitor monitoring on Instagram — from post fetching to AI-driven strategy alerts — using Claude AI, Instagram API, and multi-channel notifications. It tracks trends, analyzes performance, and delivers actionable insights via WhatsApp and email, keeping your team ahead with zero manual effort.
Key Features
  • Daily competitor scanning from Google Sheets
  • Post performance metrics (engagement rate, trends) calculated automatically
  • AI-powered insights using Claude 3.5 Sonnet for content and engagement strategies
  • Dual-channel alerts: WhatsApp (Twilio) and email for instant delivery
  • Audit logs in Google Sheets for historical trends
  • Scalable triggers: Daily schedule or webhook for ad-hoc checks
Workflow Process
Step Node Description
1 Schedule Trigger Runs daily at 10 AM or via webhook (/competitor-alert)
2 Get Competitor List Loads competitors from Competitors sheet
3 Loop Over Competitors Processes each competitor to avoid API limits
4 Get Competitor Posts Fetches last 10 posts via Instagram Graph API
5 Calculate Performance Metrics Computes avg engagement and trend using Code node
6 Generate AI Insights (Claude AI) Analyzes data for 3 strategic bullet-point insights
7 Send Email Alert Emails detailed report to team
8 Send WhatsApp Alert (Twilio) Sends concise alert via WhatsApp
9 Log Alert Records metrics and insights in AlertsLog sheet
10 End Workflow Terminates execution
Setup Instructions
1. Import Workflow
  • Open n8n → Workflows → Import from Clipboard
  • Paste the JSON workflow
2. Configure Credentials
Integration Details
Google Sheets Service account with spreadsheet access
Instagram API Business access token for media fetching
Claude AI Anthropic API key for claude-3-5-sonnet-20241022
Twilio Credentials for WhatsApp messaging
SMTP/Email SMTP or Gmail for email alerts
3. Update Spreadsheet IDs
Ensure your Google Sheets include:
  • Competitors
  • AlertsLog
4. Set Triggers
  • Webhook: /webhook/competitor-alert (for on-demand runs)
  • Schedule: Daily at 10:00 AM
5. Run a Test
Use manual execution to confirm:
  • Post fetching and metrics calculation
  • AI insights generation
  • WhatsApp/email delivery and sheet logging
Google Sheets Structure
Competitors
competitorName competitorUserId industryFocus
BrandX 1234567890 Fashion
AlertsLog
competitor avgEngagement trend insights timestamp
BrandX 75.5 Rising - Bullet 1... 2023-10-01T12:00:00Z
System Requirements
Requirement Version/Access
n8n v1.50+ (AI and messaging integrations supported)
Claude AI API claude-3-5-sonnet-20241022
Instagram Graph API Business account access token
Twilio API WhatsApp-enabled phone number
Google Sheets API https://www.googleapis.com/auth/spreadsheets
SMTP For email (e.g., Gmail OAuth)
Optional Enhancements
  • Add visual charts (e.g., engagement trends via Google Charts)
  • Integrate Slack for team-wide alerts
  • Use advanced metrics like reach/impressions via Instagram Insights API
  • Connect CRM (HubSpot) to tag competitors
  • Enable multi-platform monitoring (e.g., TikTok)
  • Add threshold-based alerts (e.g., only if engagement >20% increase)
  • Export insights to Notion or Airtable for strategy docs
Result:
A single automated system that monitors competitors, uncovers trends, and arms your team with AI strategies — delivered via WhatsApp and email with zero manual work.
Get in touch with us for custom n8n automation!
