Advanced multi-source AI research with Bright Data, OpenAI, Redis
Created by: Daniel Shashko || tomax
Daniel Shashko
Last update a month ago
How it Works
This workflow transforms natural language queries into research reports through a five-stage AI pipeline. When triggered via webhook (typically from Google Sheets using the companion google-apps-script.js (GitHub gist), it first checks Redis cache for instant results.
For new queries, GPT-4o breaks complex questions into focused sub-queries, optimizes them for search, then uses Bright Data's MCP Tool to find the top 5 credible sources (official sites, news, financial reports). URLs are scraped in parallel, bypassing bot detection.
GPT-4o extracts structured data from each source: answers, facts, entities, sentiment, quotes, and dates. GPT-4o-mini validates source credibility and filters unreliable content. Valid results aggregate into a final summary with confidence scores, key insights, and extended analysis.
Results cache for 1 hour and output via webhook, Slack, email, and DataTable—all in 30-90 seconds with 60 requests/minute rate limiting.
Who is this for?
  • Research teams needing automated multi-source intelligence
  • Content creators and journalists requiring fact-checked information
  • Due diligence professionals conducting competitive intelligence
  • Google Sheets power users wanting AI research in spreadsheets
  • Teams managing large research volumes needing caching and rate limiting
Setup Steps
Setup time: 30-45 minutes
Requirements:
  • Bright Data account (Web Scraping API + MCP token)
  • OpenAI API key (GPT-4o and GPT-4o-mini access)
  • Redis instance
  • Slack workspace (optional)
  • SMTP email provider (optional)
  • Google account (optional for Sheets integration)
Core Setup:
  1. Get Bright Data Web Scraping API token and MCP token
  2. Get OpenAI API key
  3. Set up Redis instance
  4. Configure critical nodes:
    • Webhook Entry: Add Header Auth token
    • Bright Data MCP Tool: Add MCP endpoint with token
    • Parallel Web Scraping: Add Bright Data API credentials
    • Redis Nodes: Add connection credentials
    • All GPT Nodes: Add OpenAI API key (5 nodes)
    • Slack/Email: Add credentials if using
Google Sheets Integration:
  1. Create Google Sheet
  2. Open Extensions → Apps Script
  3. Paste the companion google-apps-script.js code
  4. Update webhook URL and auth token
  5. Save and authorize
Test: {"prompt": "What is the population of Tokyo?", "source": "Test", "language": "English"}
Customization Guidance
  • Source Count: Change from 5 to 3-10 URLs per query
  • Cache Duration: Adjust from 1 hour to 24 hours for stable info
  • Rate Limits: Modify 60/minute based on usage needs
  • Character Limits: Adjust 400-char main answer to 200-1000
  • AI Models: Swap GPT-4o for Claude or use GPT-4o-mini for all stages
  • Geographic Targeting: Add more regions beyond us/il
  • Output Channels: Add Notion, Airtable, Discord, Teams
  • Temperature: Lower (0.1-0.2) for facts, higher (0.4-0.6) for analysis
Once configured, this workflow handles all web research, from fact-checking to complex analysis—delivering validated intelligence in seconds with automatic caching.
Built by Daniel Shashko
Connect on LinkedIn
