Leverage Telegram and Gemini for Seamless Integrations using Kie.ai's Veo3.1 API
Created by: Parth Pansuriya || parthpansuriya
Parth Pansuriya
Last update 9 hours ago
Create UGC Style Product Ad Video via Telegram + Gemini + Kie.ai’s Veo3.1 API
Who’s it for
  • For creators, marketers, and e-commerce sellers who want to instantly generate short UGC-style product videos from a simple Telegram message — no manual editing or video skills required.
How it works / What it does
  • This workflow automatically turns a Telegram photo and caption into a 30-second UGC-style video ad using AI.
  1. A user sends a photo + caption on Telegram.
  2. Gemini AI reads the caption and image to generate a realistic UGC script with tone, benefits, and call-to-action.
  3. The photo and script are sent to Kie.ai’s Veo3.1 API, which creates a high-quality vertical video (9:16) using the image and narration.
  4. Once rendered, the finished video ad is automatically sent back to the Telegram chat.
How to set up
  • Connect your Telegram Bot credentials.
  • Add your Google Gemini API key in the Gemini node.
  • Create a Kie.ai account and obtain your Veo3.1 API key.
  • Paste the key in the HTTP Request nodes where required.
  • Activate the workflow — send a Telegram message with a product photo + caption to test.
Requirements
  • Telegram Bot API key
  • Google Gemini API key
  • Kie.ai Veo3.1 API key
How to customize the workflow
  • Change Gemini prompt style (e.g., humorous, professional, emotional).
  • Adjust Kie.ai model parameters (aspect ratio, duration, voice, or style).
  • Add branding overlays or logos after video generation.
  • Integrate with Google Drive, Notion, or Airtable to save results automatically.
  • Modify the Telegram response to include both the video and the AI-generated script
