Search & enrich: Smart keyword analysis with Decodo + OpenAI GPT-4.1-mini
Created by: Ranjan Dailata || ranjancse
Ranjan Dailata
Last update a month ago
Disclaimer
Please note - This workflow is only available on n8n self-hosted as it's making use of the community node for the Decodo Web Scraping
Search & Enrich: Smart Keyword Analysis with Decodo + OpenAI GPT-4.1-mini
This workflow automates intelligent keyword and topic extraction from Google Search results, combining Decodo’s advanced scraping engine with OpenAI GPT-4.1-mini’s semantic analysis capabilities. The result is a fully automated keyword enrichment pipeline that gathers, analyzes, and stores SEO-relevant insights.
Who this is for
This workflow is ideal for:
  • SEO professionals who want to extract high-value keywords from competitors.
  • Digital marketers aiming to automate topic discovery and keyword clustering.
  • Content strategists building data-driven content calendars.
  • AI automation engineers designing scalable web intelligence and enrichment pipelines.
  • Growth teams performing market and search intent research with minimal effort.
What problem this workflow solves
Manual keyword research is time-consuming and often incomplete. Traditional keyword tools only provide surface-level data and fail to uncover contextual topics or semantic relationships hidden in search results.
This workflow solves that by:
  • Automatically scraping live Google Search results for any keyword.
  • Extracting meaningful topics, related terms, and entities using AI.
  • Enriching your keyword list with semantic intelligence to improve SEO and content planning.
  • Storing structured results directly in n8n Data Tables for trend tracking or export.
What this workflow does
Here’s a breakdown of the flow:
  1. Set the Input Fields – Define your search query and target geo (e.g., “Pizza” in “India”).
  2. Decodo Google Search – Fetches organic search results using Decodo’s web scraping API.
  3. Return Organic Results – Extracts the list of organic results and passes them downstream.
  4. Loop Over Each Result – Iterates through every search result description.
  5. Extract Keywords and Topics – Uses OpenAI GPT-4.1-mini to identify relevant keywords, entities, and thematic topics from each snippet.
  6. Data Enrichment Logic – Checks whether each result already exists in the n8n Data Table (based on URL).
  7. Insert or Skip – If a record doesn’t exist, inserts the extracted data into the table.
  8. Store Results – Saves both enriched search data and Decodo’s original response to disk.
End Result: A structured and deduplicated dataset containing URLs, keywords, and key topics — ready for SEO tracking or further analytics.
Pre-requisite
If you are new to Decode, please signup on this link visit.decodo.com
Please make sure to install the n8n custom node for Decodo.
Decodo Custom n8n Install
Decodo Custom n8n node
Import and Configure the Workflow
  1. Open n8n and import the JSON template.
  2. Add your credentials:
    • Decodo API Key under Decodo Credentials account.
    • OpenAI API Key under OpenAI Account.
Define Input Parameters
  • Modify the Set node to define:
    • search_query: your keyword or topic (e.g., “AI tools for marketing”)
    • geo: the target region (e.g., “United States”)
Configure Output
  • The workflow writes two outputs:
    1. Enriched keyword data → Stored in n8n Data Table (DecodoGoogleSearchResults).
    2. Raw Decodo response → Saved locally in JSON format.
Execute
Click Execute Workflow or schedule it for recurring keyword enrichment (e.g., weekly trend tracking).
How to customize this workflow
  • Change AI Model — Replace gpt-4.1-mini with gemini-1.5-pro or claude-3-opus for testing different reasoning strengths.
  • Expand the Schema — Add extra fields like keyword difficulty, page type, or author info.
  • Add Sentiment Analysis — Chain a second AI node to assess tone (positive, neutral, or promotional).
  • Export to Sheets or DB — Replace the Data Table node with Google Sheets, Notion, Airtable, or MySQL connectors.
  • Multi-Language Research — Pass a locale parameter in the Decodo node to gather insights in specific languages.
  • Automate Alerts — Add a Slack or Email node to notify your team when high-value topics appear.
Summary
Search & Enrich is a low-code AI-powered keyword intelligence engine that automates research and enrichment for SEO, content, and digital marketing.
By combining Decodo’s real-time SERP scraping with OpenAI’s contextual understanding, the workflow transforms raw search results into structured, actionable keyword insights. It eliminates repetitive research work, enhances content strategy, and keeps your keyword database continuously enriched — all within n8n.
