Automate ETL error monitoring with AI classification, Sheets logging & Jira alerts
Created by: WeblineIndia || weblineindia
WeblineIndia
Last update 16 days ago
ETL Monitoring & Alert Automation: Jira & Slack Integration
This workflow automatically processes ETL errors, extracts important details, generates a preview, creates a log URL, classifies the issue using AI and saves the processed data into Google Sheets. If the issue is important or needs attention, it also creates a Jira ticket automatically.
The workflow reduces manual debugging effort, improves visibility and ensures high-severity issues are escalated instantly without human intervention.
Quick Start – Implementation Steps
  1. Connect your webhook or ETL platform to trigger the workflow.
  2. Add your OpenAI, Google Sheets and Jira credentials.
  3. Enable the workflow.
  4. Send a sample error to verify Sheets logging and Jira ticket creation.
  5. Deploy and let the workflow monitor ETL pipelines automatically.
What It Does
This workflow handles ETL errors end-to-end by:
  • Extracting key information from ETL error logs.
  • Creating a short preview for quick understanding.
  • Generating a URL to open the full context log.
  • Asking AI to identify root cause and severity.
  • Parsing the AI output into clean fields.
  • Saving the processed error to Google Sheets.
  • Creating a Jira ticket for medium/high-severity issues.
This creates a complete automated system for error tracking, analysis and escalation.
Who’s It For
  • DevOps & engineering teams monitoring data pipelines.
  • ETL developers who want automated error reporting.
  • QA teams verifying daily pipeline jobs.
  • Companies using Jira for issue tracking.
  • Teams needing visibility into ETL failures without manual log inspection.
Requirements to Use This Workflow
  • n8n account or self-hosted instance.
  • ETL platform capable of sending error payloads (via webhook).
  • OpenAI API Key.
  • Google Sheets credentials.
  • Jira Cloud API credentials.
  • Optional: log storage URL (S3, Supabase, server logs).
How It Works & Setup Steps
1. Get ETL Error (Webhook Trigger)
Receives ETL error payload and starts the workflow.
2. Prepare ETL Logs (Code Node)
Extracts important fields and makes a clean version of the error.Generates a direct link to open the full ETL log.
3. AI Severity Classification (OpenAI / AI Agent)
AI analyzes the issue, identifies cause and assigns severity.
4. Parse AI Output (Code Node)
Formats AI results into clean fields: severity, cause, summary, recommended action.
5. Prepare Data for Logging (Set / Edit Fields)
Combines all extracted info into one final structured record.
6. Save ETL Logs (Google Sheets Node)
Logs each processed ETL error in a spreadsheet for tracking.
7. Create Jira Ticket (Jira Node)
Automatically creates a Jira issue when severity is Medium, High or Critical.
8. ETL Failure Alert (Slack Node)
Sends a Slack message to notify the team about the issue.
9. ETL Failure Notify (Gmail Node)
Sends an email with full error details to the team.
How to Customize Nodes
ETL Log Extractor
Add/remove fields based on your ETL log structure.
AI Classification
Modify the OpenAI prompt for custom severity levels or deep-dive analysis.
Google Sheets Logging
Adjust columns for environment, job name or log ID.
Jira Fields
Customize issue type, labels, priority and assignees.
Add-Ons (Extend the Workflow)
  • Send Slack or Teams alerts for high severity issues
  • Store full logs in cloud storage (S3, Supabase, GCS)
  • Add daily/weekly error summary reports
  • Connect monitoring tools like Datadog or Grafana
  • Trigger automated remediation workflows
Use Case Examples
  1. Logging all ETL failures to Google Sheets
  2. Auto-creating Jira tickets with AI-driven severity
  3. Summarizing large logs with AI for quick analysis
  4. Centralized monitoring of multiple ETL pipelines
  5. Reducing manual debugging effort across teams
Troubleshooting Guide
Issue Possible Cause Solution
Sheets not updating Wrong Sheet ID or missing permission Reconnect and reselect the sheet
Jira ticket fails Missing required fields or invalid project key Update Jira mapping
AI output empty Invalid OpenAI key or exceeded usage Check API key or usage limits
Severity always “low” Prompt too broad Adjust AI prompt with stronger rules
Log preview empty Incorrect error field mapping Verify the structure of the ETL error JSON
Need Help?
For assistance setting up this workflow, customizing nodes or adding additional features, feel free to contact our n8n developers at WeblineIndia. We can help configure, scale or build similar automation workflows tailored to your ETL and business requirements.
