Inventory reconciliation between Notion & Airtable with GPT-4o Slack alerts
Created by: Rahul Joshi || rahul08
Rahul Joshi
Last update 23 days ago
📘 Description
This workflow performs automated inventory reconciliation between Notion (physical counts) and Airtable (system counts), ensuring both databases stay synchronized.
It fetches records from both systems, merges them into a unified comparison payload, validates the structure, and calculates discrepancies.
If a mismatch is detected, the workflow automatically updates Airtable with the corrected count and notifies the operations team on Slack.
If everything matches, a simple “No action needed” Slack message is sent.
Any malformed or incomplete payloads are logged into Google Sheets for audit tracking.
⚙️ What This Workflow Does (Step-by-Step)
🟢 Manual Trigger – Execute Workflow
Starts the reconciliation process on demand.
📥 Fetch Records from Notion
Retrieves physical stock data (cycle count) stored in Notion.
📦 Fetch Records from Airtable
Loads inventory data from Airtable’s system-of-record table.
🔀 Merge Notion + Airtable Inputs
Combines both datasets into a single payload for unified processing.
🔍 Validate Payload Structure (IF Node)
Ensures that key fields (like id) exist.
Valid → continue
Invalid → logged to Google Sheets.
🧾 Log Invalid Versioning Requests to Google Sheets
Stores broken or incomplete payload entries for later review.
🧮 Build Combined Notion + Airtable Payload (Code Node)
Constructs the structured comparison object:
{ notion: {...}, airtable: [...] }
📊 Compare Notion Record With Airtable Record (Code Node)
Performs core reconciliation logic:
Matches items by name
Compares physical vs. system count
Calculates difference
Determines if a correction is needed
If mismatch → flagged for update.
🔎 Check If Record Requires Update (IF Node)
Branches logic into:
Mismatch → Update Airtable + Alert
Match → No action summary
🛠️ Update Airtable Record With Corrected Count
Writes the accurate physical count from Notion into Airtable.
🧠 Configure GPT-4o – Slack Summary Models
Two models:
For “no action needed” summaries
For “Airtable updated” discrepancy alerts
🤖 Generate Slack Summary / Generate Slack Summary1
AI produces short, precise, operations-friendly Slack messages based on whether a discrepancy existed.
💬 Slack – Send Summary Notification / Send Update Notification
Sends final Slack message to the operations user, confirming:
Stock match status
Updates made
Item details
Difference values
🧩 Prerequisites
  • Notion API integration
  • Airtable API credentials
  • Azure OpenAI GPT-4o
  • Slack API connection
  • Google Sheets OAuth
💡 Key Benefits
✔ Eliminates manual reconciliation errors
✔ Keeps Airtable continuously aligned with real physical counts
✔ Provides instant Slack visibility to operations teams
✔ Logs all invalid or malformed cases
✔ Centralizes Notion + Airtable consistency checks
👥 Perfect For
  • Operations teams managing multi-system inventory
  • Warehouse cycle count workflows
  • Audit-driven companies needing accurate stock data
  • Businesses using Notion + Airtable as parallel systems
