Smart Gmail auto-labeler with Gemini AI & sender history
Last update 3 days ago
n8n Gmail AI Auto-Labeler
An intelligent n8n workflow that automatically classifies and labels Gmail emails using Google Gemini AI, keeping your inbox organized with zero manual effort.
This workflow uses AI-powered classification to analyze email content, learn from sender patterns, and automatically apply appropriate labels while archiving processed emails.
How It Works
  1. Trigger: The workflow runs automatically every minute to check for new unread emails (or manually for bulk processing).
  2. Check for Existing Labels: Before processing, it verifies if the email already has an AI-assigned label to avoid duplicate processing.
  3. AI Classification: If unlabeled, the AI agent analyzes the email using:
    • Sender History Tool - Fetches up to 10 previous emails from the same sender to identify patterns
    • 80% Majority Rule - If 80%+ of sender's past emails have the same label, strongly prefers that category
    • Label Examples Tool - When uncertain, compares the email with existing examples from suspected categories
  4. Smart Decision: The AI returns a structured JSON response:
      "label": "Category Name"
    Or "None" if no category fits.
  5. Apply & Archive:
    • Label Applied → The workflow adds the appropriate Gmail label to the thread.
    • Auto-Archive → Removes the email from INBOX (archives it) to maintain zero-inbox.
  6. Loop: Processes the next email in the batch, ensuring all new emails are classified.
Requirements
  • Gmail OAuth2 Credentials - Connected Gmail account with API access.
  • Google Gemini API Key - Get it here
    • Free tier: 15 requests/minute
  • Gmail Labels - Must be created in Gmail exactly as listed:
    • Meetings
    • Income
    • Inquiries
    • Notify / Verify
    • Expenses
    • Orders / Deliveries
    • Trash Likely
How to Use
  1. Import the Workflow:
    • Copy the provided JSON file.
    • In your n8n instance → click Import Workflow → select the JSON file.
  2. Create Gmail Labels:
    • Open Gmail → Settings → Labels → Create new labels.
    • Use the exact names listed above (case-sensitive).
  3. Get Your Label IDs:
    • In the workflow, click "When clicking 'Execute workflow'" manual trigger.
    • Execute the "Get Labels Info" node only.
    • Copy each label's ID (format: Label_1234567890123456789).
  4. Update Code Nodes with Your Label IDs:
    Node 1: "Check Label Existence"
    const labelMap = {
      "Label_YOUR_ID_HERE": "Meetings",
      "Label_YOUR_ID_HERE": "Inquiries",
      "Label_YOUR_ID_HERE": "Notify / Verify",
      "Label_YOUR_ID_HERE": "Expenses",
      "Label_YOUR_ID_HERE": "Orders / Deliveries",
      "Label_YOUR_ID_HERE": "Trash Likely"
    Node 2: "Convert Label to Label ID"
    const labelToId = {
      "Meetings": "Label_YOUR_ID_HERE",
      "Inquiries": "Label_YOUR_ID_HERE",
      "Notify / Verify": "Label_YOUR_ID_HERE",
      "Expenses": "Label_YOUR_ID_HERE",
      "Orders / Deliveries": "Label_YOUR_ID_HERE",
      "Trash Likely": "Label_YOUR_ID_HERE"
  5. Set Up Credentials:
    • Gmail OAuth2 → Authorize your Gmail account in n8n.
    • Google Gemini API → Add your API key in n8n credentials.
  6. Test the Workflow:
    • Send yourself test emails with clear content (e.g., invoice, meeting invite).
    • Use the manual trigger to process them.
    • Verify labels are applied correctly.
  7. Activate for Auto Mode:
    • Toggle the workflow to Active.
    • New unread emails will be processed automatically every minute.
Notes
  • Dual Execution Modes:
    • Auto Mode - Gmail Trigger polls inbox every minute for unread emails (real-time processing).
    • Manual Mode - Use the manual trigger to bulk process existing emails (adjust limit in "Get many messages" node).
  • AI Learning from Patterns:
    • The workflow applies an 80% majority rule - if 80% or more of a sender's historical emails share the same label, the AI strongly prefers that category for new emails from that sender.
    • This creates intelligent sender-based routing over time.
  • Skip Already Labeled Emails:
    • The "Check Label Existence" node prevents re-processing emails that already have an AI-assigned label.
    • Ensures efficient execution and avoids duplicate work.
  • Structured AI Output:
    • Uses a Structured Output Parser to ensure the AI always returns valid JSON: { "label": "Category" }.
    • If uncertain, returns { "label": "None" } and the email stays in inbox.
  • Background Archiving:
    • After labeling, emails are automatically removed from INBOX (archived).
    • Maintains a zero-inbox workflow while preserving emails under their labels.
  • Rate Limits:
    • Google Gemini free tier: 15 requests/minute.
    • Adjust polling frequency if hitting limits.
Example Behavior
  • Minute 1: New invoice email arrives → AI fetches sender history → 85% were labeled "Expenses" → applies "Expenses" label → archives email.
  • Minute 2: Meeting invite arrives → No sender history → AI analyzes content (Zoom link, time) → applies "Meetings" label → archives email.
  • Minute 3: Promotional email arrives → AI compares with "Trash Likely" examples → applies label → archives email.
  • Minute 4: Already-labeled email detected → skipped silently.
Label Categories
Label Description
Meetings Calendar invites, Zoom/Meet links, appointments, scheduled events
Expenses Bills, invoices, receipts, payment reminders, subscription renewals
Income Payments received, payouts, deposits, earnings notifications
Notify / Verify Verification codes, login alerts, 2FA codes, account notifications
Orders / Deliveries Order confirmations, shipping updates, tracking numbers, deliveries
Inquiries Business outreach, sales proposals, partnerships, cold emails
Trash Likely Spam, newsletters, promotions, marketing blasts, ads
If no category fits clearly, the email returns "None" and remains in the inbox.
Customization
  • Change Polling Frequency: Edit the "Gmail Trigger" node → pollTimesmode (e.g., every5Minutes).
  • Adjust Email Limit: Modify limit: 10 in "Get many messages" node for manual bulk processing.
  • Add Custom Labels: Create in Gmail → Get ID → Update both Code nodes + AI system prompt.
  • Modify 80% Rule: Edit the AI agent's system message to adjust the majority threshold.
  • Increase Tool Limits: Change limit: 10 in Gmail tool nodes to fetch more historical data.
Author: Muhammad Anas Farooq
