Automate Document Q&A with Multi-Agent RAG Orchestration using Contextual AI & Gemini
Created by: Jinash Rouniyar || jinash
Jinash Rouniyar
Last update a month ago
PROBLEM
Managing multiple RAG AI agents can be complex when each has its own purpose and vector database.
  • Manually tracking agents and deciding which one to query wastes time.
  • LLMs often struggle to determine which agent best fits a user’s request.
This workflow enables automated multi-agent orchestration, dynamically selecting and querying the correct agent using Contextual AI Query Tool and Gemini 2.5 Flash.
  • A form trigger allows users to create new agents by specifying a name, description, datastore, and uploading files.
  • A new agent is created with the provided information and files are ingested in the datastore
  • We get the status of file ingestion every 30 seconds until the ingestion process is complete
  • When users send queries, the Agent Orchestrator identifies the most relevant agent to generate grounded, context-aware responses.
Note: The document ingestion process is asynchronous and may take a few minutes before your agent has the document fully available in the datastore for querying.
How to set up
  • Create a free Contextual AI account and obtain your CONTEXTUALAI_API_KEY.
  • Add CONTEXTUALAI_API_KEY as an environment variable in n8n.
  • For the baseline model, we have used Gemini 2.5 Flash Model, you can find your Gemini API key here
How to customize the workflow
  • Replace the Form Trigger with a Webhook Trigger or manual input to integrate with custom systems.
  • Swap Gemini 2.5 Flash with another LLM provider
  • Update the wait time as per user requirement
  • Modify the system prompt to fine-tune how the orchestration logic selects and queries agents.
  • You can check out this Contextual AI API reference for more details on agent creation and usage.
  • If you have feedback or need support, please email [email protected].
