Automate invoice processing & stock management with AI, Gmail, Sheets & Slack
Last update 16 days ago
✅ What problem does this workflow solve?
Order processing often involves manual invoice reading, stock checking, and back-and-forth communication between procurement and operations teams. This workflow automates the entire procurement decision flow — from reading incoming order emails to extracting structured data, checking stock, and creating either a purchase requisition or a work order automatically.
💡 Main Use Cases
  • 📥 Auto-extract order and invoice details from incoming emails
  • 📦 Validate stock availability before processing orders
  • 📝 Auto-create Purchase Requisitions when stock is insufficient
  • 🛠 Auto-create Work Orders when stock is available
  • 📧 Notify procurement or operations via email & Slack
  • 📊 Log every action in Google Sheets for tracking and audit
🧠 How It Works – Step-by-Step
1. 📧 Gmail Trigger
The workflow begins when a new email arrives at a specific email address.
The invoice file is automatically downloaded for processing.
2. 📑 Extract Invoice Record
The attached invoice is processed using OCR or a document extraction tool.
Raw details such as:
  • Order ID
  • Item code
  • Quantity
  • Customer information
are extracted for further processing.
3. 🤖 AI-Powered Data Structuring
OpenAI structures the extracted fields into a clean and consistent format:
  • order_id
  • item_code
  • quantity
  • customer_name
This ensures all data is normalised before stock validation.
4. 📦 Stock Check
The workflow checks inventory data stored in Google Sheets.
It compares:
  • Required quantity
  • Current stock
If stock is insufficient, it triggers the purchase requisition path.
If stock is available, it initiates the work order path.
5. 🔀 Conditional Flow
If stock is insufficient:
  • Creates a Purchase Requisition record in Google Sheets
  • Sends an email notification to the procurement team for approval
If stock is sufficient:
  • Creates a Work Order entry in Google Sheets
  • Sends a Slack summary message to the operations team
This ensures teams are notified instantly, and work continues without delays.
📊 Logging & Reporting
Every step — extracted data, PR created, WO created, notifications sent — is logged in Google Sheets.
This provides a full audit trail for procurement and operations teams.
👤 Who can use this?
Ideal for:
  • Procurement teams
  • Operations departments
  • Manufacturing & warehouse units
  • Businesses processing high-volume emailed orders
  • Any team needing structured, automated order workflows
🚀 Benefits
  • ⏱ Faster order processing
  • 🧠 Fewer manual errors from invoice reading
  • 📦 Smarter procurement decisions based on real stock
  • 🔁 Automated communication loops
  • 📊 Transparent audit logs for every order
