Track & alert public transport delays using ScrapeGraphAI, Teams and Todoist
Created by: vinci-king-01 || vinci-king-01
vinci-king-01
Last update a month ago
Public Transport Delay Tracker with Microsoft Teams and Todoist
⚠️ COMMUNITY TEMPLATE DISCLAIMER: This is a community-contributed template that uses ScrapeGraphAI (a community node). Please ensure you have the ScrapeGraphAI community node installed in your n8n instance before using this template.
This workflow continuously monitors public-transportation websites and apps for real-time schedule changes and delays, then posts an alert to a Microsoft Teams channel and creates a follow-up task in Todoist. It is ideal for commuters or travel coordinators who need instant, actionable updates about transit disruptions.
Pre-conditions/Requirements
Prerequisites
  • An n8n instance (self-hosted or n8n cloud)
  • ScrapeGraphAI community node installed
  • Microsoft Teams account with permission to create an Incoming Webhook
  • Todoist account with at least one project
  • Access to target transit authority websites or APIs
Required Credentials
  • ScrapeGraphAI API Key – Enables scraping of transit data
  • Microsoft Teams Webhook URL – Sends messages to a specific channel
  • Todoist API Token – Creates follow-up tasks
  • (Optional) Transit API key if you are using a protected data source
Specific Setup Requirements
Resource What you need
Teams Channel Create a channel → Add “Incoming Webhook” → copy the URL
Todoist Project Create “Transit Alerts” project and note its Project ID
Transit URLs/APIs Confirm the URLs/pages contain the schedule & delay elements
Key Steps:
  • Webhook (Trigger): Starts the workflow on a schedule or via HTTP call.
  • Set Node: Defines target transit URLs and parsing rules.
  • ScrapeGraphAI Node: Scrapes live schedule and delay data.
  • Code Node: Normalizes scraped data, converts times, and flags delays.
  • IF Node: Determines if a delay exceeds the user-defined threshold.
  • Microsoft Teams Node: Sends formatted alert message to the selected Teams channel.
  • Todoist Node: Creates a “Check alternate route” task with due date equal to the delayed departure time.
  • Sticky Note Node: Holds a blueprint-level explanation for future editors.
Set up steps
Setup Time: 15–20 minutes
  1. Install community node: In n8n, go to “Manage Nodes” → “Install” → search for “ScrapeGraphAI” → install and restart n8n.
  2. Create Teams webhook: In Microsoft Teams, open target channel → “Connectors” → “Incoming Webhook” → give it a name/icon → copy the URL.
  3. Create Todoist API token: Todoist → Settings → Integrations → copy your personal API token.
  4. Add credentials in n8n: Settings → Credentials → create new for ScrapeGraphAI, Microsoft Teams, and Todoist.
  5. Import workflow template: File → Import Workflow JSON → select this template.
  6. Configure Set node: Replace example transit URLs with those of your local transit authority.
  7. Adjust delay threshold: In the Code node, edit const MAX_DELAY_MINUTES = 5; as needed.
  8. Activate workflow: Toggle “Active”. Monitor executions to ensure messages and tasks are created.
Node Descriptions
Core Workflow Nodes:
  • Webhook – Triggers workflow on schedule or external HTTP request.
  • Set – Supplies list of URLs and scraping selectors.
  • ScrapeGraphAI – Scrapes timetable, status, and delay indicators.
  • Code – Parses results, converts to minutes, and builds payloads.
  • IF – Compares delay duration to threshold.
  • Microsoft Teams – Posts formatted adaptive-card-style message.
  • Todoist – Adds a task with priority and due date.
  • Sticky Note – Internal documentation inside the workflow canvas.
Data Flow:
  1. WebhookSetScrapeGraphAICodeIF
    a. IF (true branch)Microsoft TeamsTodoist
    b. IF (false branch) → (workflow ends)
Customization Examples
Change alert message formatting
// In the Code node
const message = `⚠️ Delay Alert:
Route: ${item.route}
Expected: ${item.scheduled}
New Time: ${item.newTime}
Delay: ${item.delay} min
Link: ${item.url}`;
return [{ json: { message } }];
Post to multiple Teams channels
// Duplicate the Microsoft Teams node and reference a different credential
items.forEach(item => {
  item.json.webhookUrl = $node["Set"].json["secondaryChannelWebhook"];
return items;
Data Output Format
The workflow outputs structured JSON data:
  "route": "Blue Line",
  "scheduled": "2024-12-01T14:25:00Z",
  "newTime": "2024-12-01T14:45:00Z",
  "delay": 20,
  "status": "Delayed",
  "url": "https://transit.example.com/blue-line/status"
Troubleshooting
Common Issues
  1. Scraping returns empty data – Verify CSS selectors/XPath in the Set node and ensure the target site hasn’t changed its markup.
  2. Teams message not sent – Check that the stored webhook URL is correct and the connector is still active.
  3. Todoist task duplicated – Add a unique key (e.g., route + timestamp) to avoid inserting duplicates.
Performance Tips
  • Limit the number of URLs per execution when monitoring many routes.
  • Cache previous scrape results to avoid hitting site rate limits.
Pro Tips:
  • Use n8n’s built-in Cron instead of Webhook if you only need periodic polling.
  • Add a SplitInBatches node after scraping to process large route lists incrementally.
  • Enable execution logging to an external database for detailed audit trails.
