Sync Shopify products to WooCommerce with Gemini, BrowserAct and Slack
Last update a month ago
Sync Shopify products to WooCommerce with AI enhancement
This workflow automates the process of synchronizing your Shopify catalog to WooCommerce, enriching product data along the way. It uses AI to identify the best external sources (like Amazon or G2) for additional product details, scrapes that data using BrowserAct, synthesizes a high-converting description, and then pushes the enhanced product to your WooCommerce store.
Target Audience
Dropshippers, e-commerce store owners managing multiple storefronts, and digital marketers looking to automate product data enrichment.
  1. Fetch Products: The workflow starts by retrieving all products from your Shopify store.
  2. Classify & Research: An AI Agent analyzes each product title to determine the best source for external data (e.g., physical goods -> Amazon, software -> G2).
  3. Scrape Data: BrowserAct executes a background task to scrape the target site for specifications, reviews, and images.
  4. Enhance Content: A second AI Agent (acting as a copywriter) processes the scraped data to write a compelling HTML description, generate a logical SKU, and format image lists.
  5. Sync to WooCommerce: The workflow checks if the product already exists in WooCommerce via SKU check. If not, it creates a new product with the enriched data.
  6. Error Handling: If product creation fails, a notification is sent to Slack.
How to set up
  1. Configure Credentials: Connect your Shopify, WooCommerce, Slack, BrowserAct, and Google Gemini accounts in n8n.
  2. Prepare BrowserAct: Ensure the Shopify to WooCommerce Multi-Store Sync template is saved in your BrowserAct account.
  3. Configure Notifications: Open the Notify user and Send Error nodes to select your preferred Slack channel.
  4. Activate: Run the workflow manually to start the sync.
Requirements
  • BrowserAct account with the Shopify to WooCommerce Multi-Store Sync template.
  • Shopify account (Access Token).
  • WooCommerce account (API Key/Secret).
  • Google Gemini account.
  • Slack account.
How to customize the workflow
  1. Filter Products: Add logic after the "Get many products" node to only sync specific collections or tags.
  2. Change AI Persona: Modify the system prompt in the Create Product agent to change the tone of the product descriptions (e.g., more technical vs. more salesy).
  3. Add More Sources: Update the Analyze the Products agent to include other data sources like eBay or Best Buy.
Need Help?
Workflow Guidance and Showcase Video
