Monitor viral Reddit posts and send GPT-4o-mini summaries to Telegram
Created by: Roshan Ramani || rawsun007
Roshan Ramani
Last update 14 days ago
Who's it for
This workflow is perfect for:
  • Content creators who need to stay on top of trending topics
  • Marketers tracking industry discussions and competitor mentions
  • Community managers monitoring relevant subreddits
  • Researchers gathering trending content in specific niches
  • Anyone who wants curated Reddit updates without manual browsing
What it does
This automated workflow:
  • Monitors multiple subreddits for viral posts daily
  • Filters posts based on engagement metrics (upvotes and recency)
  • Generates concise AI summaries of trending content
  • Delivers formatted updates directly to your Telegram chat
  • Runs completely hands-free once configured
Step 1: Configuration & Scheduling
  • Triggers daily at 8 AM (customizable)
  • Loads your configured subreddit niches and Telegram settings
Step 2: Data Collection
  • Loops through each subreddit in your niche list
  • Fetches the 50 newest posts from each subreddit
  • Extracts key data: title, URL, upvotes, timestamp, subreddit name
Step 3: Smart Filtering
  • Applies viral post criteria:
    • Posts with 500+ upvotes, OR
    • Posts with 70+ upvotes created within the last 24 hours
  • Ensures only high-engagement content passes through
Step 4: AI Summarization
  • Aggregates all filtered posts into a single batch
  • Sends to GPT-4o-mini for analysis
  • Generates concise 100-200 word summaries
  • Formats output for Telegram markdown
Step 5: Delivery
  • Sends all summaries to your Telegram chat
  • Includes post links and engagement metrics
  • Delivers in a clean, readable format
Setup steps
1. Configure Reddit credentials
  • Connect your Reddit OAuth2 API credentials in the "Get Reddit Viral Posts" node
  • Ensure you have API access enabled on your Reddit account
2. Configure Telegram credentials
  • Add your Telegram bot token in the "Send to Telegram" node
  • Get your chat ID by messaging your bot and checking updates
3. Customize your niches
  • Open the "Workflow Configuration" node
  • Edit the niches array with your target subreddits
  • Default niches: technology, programming, science, gaming
4. Set your Telegram chat ID
  • Replace the default chat ID (7917193308) in "Workflow Configuration"
  • Use your personal chat ID or group chat ID
5. Adjust the schedule (optional)
  • Modify the "Daily 8 AM Trigger" to your preferred time
  • Change frequency if you want multiple updates per day
6. Test before activating
  • Run the workflow manually using the "Test workflow" button
  • Verify summaries arrive in Telegram correctly
  • Check that filtering logic works as expected
Requirements
Required credentials:
  • Reddit OAuth2 API access (free)
  • Telegram bot token (free via @BotFather)
  • OpenAI API key for GPT-4o-mini (paid)
Platform requirements:
  • n8n instance (self-hosted or n8n Cloud)
  • Active internet connection
  • Sufficient API rate limits for your usage
Technical knowledge:
  • Basic understanding of n8n workflows
  • Ability to generate API credentials
  • Familiarity with Telegram bots (helpful but not required)
How to customize
Adjust subreddit monitoring:
  • Add or remove subreddits in the niches array
  • Format: ["subreddit1", "subreddit2", "subreddit3"]
  • Example: ["machinelearning", "datascience", "artificial"]
Modify viral post criteria:
  • Edit the "Filter" node conditions
  • Change upvote thresholds (default: 500+ or 70+ within 24h)
  • Adjust time window for recency checks
Customize AI summaries:
  • Update the system prompt in "AI Summarizer" node
  • Change summary length (default: 100-200 words)
  • Modify tone, style, or focus areas
  • Switch to different OpenAI models if needed
Change scheduling:
  • Modify trigger time in "Daily 8 AM Trigger"
  • Options: hourly, twice daily, weekly, custom cron
  • Consider API rate limits when increasing frequency
Adjust data collection:
  • Change the limit parameter in "Get Reddit Viral Posts"
  • Default: 50 posts per subreddit
  • Higher limits = more comprehensive but slower execution
Enhance filtering logic:
  • Add additional criteria (comments count, awards, etc.)
  • Create category-specific thresholds
  • Filter by post type (text, link, image)
Format Telegram output:
  • Modify parse_mode in "Send to Telegram" node
  • Options: Markdown, HTML, or plain text
  • Customize message structure and styling
