Monitor backlinks and generate SEO insights with SE Ranking and GPT-4.1-mini
Created by: Ranjan Dailata || ranjancse
Ranjan Dailata
Last update 24 days ago
This n8n workflow automates backlink monitoring, analysis, and AI-driven interpretation for any domain or URL. It combines backlink intelligence from SE Ranking with structured reasoning and summarization powered by OpenAI GPT 4.1-mini.
Instead of manually reviewing backlink reports, this workflow transforms raw backlink metrics into clear, human-readable SEO insights and persists them to multiple storage layers for reporting and tracking.
Who this is for?
This workflow is ideal for:
  • SEO professionals and technical SEO teams
  • Digital marketing agencies managing multiple domains
  • Growth and content teams tracking backlink quality
  • Developers building SEO intelligence pipelines
  • Data teams using n8n for enrichment and reporting
What this workflow does?
  1. Accepts a backlink query (domain, host, or URL)
  2. Uses multiple SE Ranking Backlinks API endpoints to retrieve:
    • Backlink summary metrics
    • Referring domains, IPs, and subnets
    • Authority and backlink quality indicators
    • Raw backlink lists
  3. Routes the data through an AI Agent powered by GPT-4.1-mini that:
    • Selects the appropriate backlink dataset automatically
    • Normalizes noisy SEO data
    • Generates structured summaries without subjective opinions
  4. Produces a clean backlink intelligence summary
  5. Persists results to:
    • n8n DataTables
    • Google Sheets
    • CSV / JSON exports
If you are new to SE Ranking, please signup on https://seranking.com
Prerequisites
  • Active SE Ranking API access
  • OpenAI API key with GPT-4.1-mini enabled
  • n8n instance (self-hosted or cloud)
  • Basic understanding of backlink and authority metrics
  1. Import the workflow JSON into n8n
  2. Configure credentials:
  • SE Ranking using HTTP Header Authentication. Please make sure to set the header authentication as below. The value should contain a Token followed by a space with the SE Ranking API Key.
  • OpenAI API (GPT-4.1-mini)
  • Google Sheets OAuth (optional, for reporting)
  1. Open the Set Input Fields node and define:
  2. Verify storage destinations:
    • Google Sheet ID and sheet name
    • n8n DataTable
    • File export nodes (CSV / JSON)
  3. Click Execute Workflow
How to customize this workflow to your needs?
You can easily extend or adapt this workflow by:
  • Switching analysis mode (domain, host, or URL)
  • Adding historical backlink trend analysis
  • Enhancing the AI prompt to generate:
    • Toxic backlink alerts
    • Link-building opportunities
    • Competitor backlink gap analysis
  • Replacing storage with:
    • Databases or data warehouses
    • Slack / Email notifications
    • BI dashboards
  • Scheduling the workflow for continuous backlink monitoring
Summary
This n8n template delivers an end-to-end backlink intelligence system from raw backlink retrieval to AI-powered interpretation and structured storage. By combining SE Ranking’s backlink data with OpenAI-driven reasoning, it eliminates manual SEO analysis and enables scalable, repeatable backlink monitoring.
