Multi-AI Council Research 🔍: GPT 5.2, Claude Opus 4.6 & Gemini 3 Pro Aggregation
Created by: Davide Boizza || n3witalia
Davide Boizza
Last update 2 months ago
This workflow implements a multi-model AI orchestration with the BEST models at now (ChatGPT 5.2, Claude Opus 4.6, Gemini 3 Pro) and response aggregation system designed to handle user chat inputs intelligently and reliably.
Key Advantages
1. ✅ Higher Answer Quality
By combining multiple top-tier AI models, the workflow reduces blind spots and single-model bias, resulting in more accurate and nuanced answers.
2.✅ Built-in Reliability and Redundancy
If one model underperforms or misunderstands the query, the others compensate, improving robustness and consistency.
3. ✅ Intelligent Query Handling
The search classification and optimization layer ensures that:
  • research queries are handled with precision,
  • casual conversation is not over-processed,
  • model resources are used efficiently.
4. ✅ Balanced and Transparent Reasoning
Contradictions between models are not hidden. Instead, they are reconciled or clearly explained, increasing trust in the final output.
5. ✅ Scalability and Extensibility
The architecture makes it easy to:
  • add new models,
  • swap providers,
  • experiment with different aggregation strategies,
    without redesigning the entire workflow.
6. ✅ Enterprise-Ready Design
This approach is well suited for:
  • research assistants,
  • decision-support tools,
  • knowledge management systems,
  • high-stakes professional use cases where answer quality matters more than speed alone.
How it Works
  1. Input Processing: When a chat message is received, it's sent to a "Search Query Optimizer" that determines whether the input is a research query or general conversation. If it's a search query, it's optimized for better search results.
  2. Multi-Model Query Execution: If the input is classified as a research query, the workflow simultaneously sends the optimized query to three different AI models:
    • ChatGPT 5.2 (OpenAI)
    • Claude Opus 4.6 (Anthropic)
    • Gemini 3 Pro (Google)
  3. Response Aggregation: Each model's response is collected separately, then all three responses are sent to a "Multi-Response Aggregator" which synthesizes them into a single comprehensive answer.
  4. Fallback Handling: If the input is not a research query, the workflow bypasses the multi-model execution and sends a default message asking the user to enter a research text.
Set up Steps
  1. Model Configuration: Ensure you have valid API credentials set up for:
    • OpenAI (for ChatGPT 5.2)
    • Anthropic (for Claude Opus 4.6)
    • Google Gemini (for both query optimization and Gemini 3 Pro)
  2. Connection Verification: Confirm all node connections are properly established in the workflow editor, particularly:
    • Chat trigger to Search Query Optimizer
    • Conditional branch routing based on query classification
    • Parallel connections to the three AI models
    • Response collection to the aggregator
  3. Prompt Customization: Review and adjust the system prompts in:
    • Search Query Optimizer (for query classification rules)
    • Multi-Response Aggregator (for synthesis guidelines)
    • Each model's chain nodes (if specific formatting is required)
  4. Testing: Activate the workflow and test with various inputs to verify:
    • Proper classification of research vs. non-research queries
    • Simultaneous execution of all three AI models
    • Correct aggregation of responses
    • Appropriate fallback message for non-research inputs
👉 Subscribe to my new YouTube channel. Here I’ll share videos and Shorts with practical tutorials and FREE templates for n8n.
Need help customizing?
Contact me for consulting and support or add me on Linkedin.
