Optimize Webflow CMS SEO metadata using MCP and GPT‑4o-mini
Created by: Dahiana || mssporto
Dahiana
Last update a month ago
Who's it for
Marketing teams, content creators, and agencies managing Webflow CMS sites who need to optimize SEO metadata at scale.
The workflow fetches CMS items from Webflow, then uses AI to rewrite titles and descriptions to meet SEO best practices (50-60 character titles, 120-155 character meta descriptions). It automatically publishes changes back to Webflow and logs all updates to Google Sheets for audit purposes.
Requirements
  • Webflow site with CMS collections
  • MCP Webflow OAuth2 credentials
  • Any LLM api
  • Google Sheets for logging (optional)
How to set up
  1. Get your collection ID: In Webflow, go to your CMS collection → copy the collection ID
  2. Update Set Fields node: Replace collectionId with yours
  3. Update Format for Update node: Replace collectionId
  4. Match field names: If your collection uses different fields than "name" and "project-summary", update the agent prompt and Format for Update code
  5. Test first: Set batch size to 1 and run on a single item
  6. Scale up: Increase batch size gradually
How to customize
Change character limits: Adjust minTitleLength, maxTitleLength, minSummaryLength, maxSummaryLength in Set Fields node. Add more fields like alt-text, post body, slug, etc.
Different field names: Update agent system prompt, Structured Output Parser schema, and Format for Update code
