Enrich Airtable company records with web research using OpenAI GPT-4o
Last update 15 days ago
Video Introduction
Video Walkthrough
Want to automate your inbox or need a custom workflow? 📞 Book a Call | 💬 DM me on Linkedin
What This Workflow Does
This workflow automatically enriches your Airtable company database with AI-powered research. Whenever a new company is added to your Airtable base, an AI agent searches the web to discover the company's website and generates a concise 1-2 sentence summary of their business activities. The workflow then updates the Airtable record with these findings, eliminating manual research and keeping your data complete and current.
Key Benefits
  • Automated data enrichment: No more manual web searches for company information
  • AI-powered accuracy: Uses OpenAI with web search capabilities to find reliable, up-to-date information
  • Structured output: Returns data in a predictable JSON format for consistent record updates
  • Real-time processing: Triggers immediately when new companies are added
Setup Requirements
Airtable Configuration:
  • Your Companies table must have a Created time field to trigger the workflow
  • Create an Airtable Personal Access Token at airtable.com/create/tokens with these scopes: data.records:read, data.records:write, and schema.bases:read
  • Ensure your table has fields for Website and Company Details (or modify the field mappings accordingly)
OpenAI Setup:
  • Register for an OpenAI account and obtain an API key
  • Add your OpenAI credentials in n8n
Workflow Configuration:
  • Update the Airtable Trigger node with your base and table URLs
  • Update the Airtable Update node with your specific base and table information
  • Customize the AI prompt if you need different research parameters or output fields
Once published, the workflow runs automatically whenever a new company is added to your table.
