Screen CVs with OpenAI and PostgreSQL using chained prompts
Created by: Lucas Hideki || lucashideki
Lucas Hideki
Last update 21 days ago
  • Webhook receives a job ID and list of candidate IDs from your database
  • If the job has no template yet, Prompt 0 reads the job description and automatically extracts mandatory requirements, differentials, behavioral competencies and sets the weight of each criterion
  • For each candidate, 3 prompts run sequentially with accumulated context:
    • Prompt 1 scores the candidate (0–100) against the job template using calibration anchors to avoid score inflation, plus a breakdown score per criterion
    • Prompt 2 receives the score as context and identifies strengths with concrete resume evidence, separating critical gaps (missing mandatory requirements) from secondary gaps (missing differentials)
    • Prompt 3 receives the gaps as context and generates personalized interview questions for that specific candidate — not generic HR templates
  • Results are saved directly to PostgreSQL after each candidate
  • When all candidates are processed, Prompt 4 automatically generates an executive summary of the entire pool with recommendations on who to interview
Set up steps
  • Add your OpenAI credentials to all AI nodes (~2 min)
  • Add your PostgreSQL credentials to all Postgres nodes (~2 min)
  • Create the required tables using the SQL schema provided in the workflow sticky note (~5 min)
  • Trigger via POST /webhook/cv-analyze with { "job_id": 1, "candidate_ids": [1, 2, 3] }
