Monitor PostgreSQL data quality and generate remediation alerts with Slack
Created by: ResilNext || rnair1996
ResilNext
Last update 22 days ago
Autonomous PostgreSQL Data Quality Monitoring & Remediation
Overview
This workflow automatically monitors PostgreSQL database data quality and detects structural or statistical anomalies before they impact analytics, pipelines, or applications.
Running every 6 hours, it scans database metadata, table statistics, and historical baselines to identify:
  • Schema drift
  • Null value explosions
  • Abnormal data distributions
Detected issues are evaluated using a confidence scoring system that considers severity, frequency, and affected data volume. When issues exceed the defined threshold, the workflow generates SQL remediation suggestions, logs the issue to an audit table, and sends alerts to Slack.
This automation enables teams to proactively maintain database reliability, detect unexpected schema changes, and quickly respond to data quality problems.
How It Works
1. Scheduled Monitoring
A Schedule Trigger starts the workflow every 6 hours to run automated database quality checks.
2. Metadata & Statistics Collection
The workflow retrieves important metadata from PostgreSQL:
  • Schema metadata from information_schema.columns
  • Table statistics from pg_stat_user_tables
  • Historical baselines from a baseline tracking table
These datasets allow the workflow to compare current database conditions against historical norms.
3. Data Quality Detection Engine
Three parallel detection checks analyze the database:
Schema Drift Detection
  • Identifies new tables or columns
  • Detects removed columns or tables
  • Detects datatype or nullability changes
Null Explosion Detection
  • Calculates null percentage per column
  • Flags columns exceeding configured null thresholds
Outlier Distribution Detection
  • Compares current column statistics against historical baselines
  • Uses statistical deviation (z-score) to detect abnormal distributions
4. Issue Aggregation & Confidence Scoring
All detected issues are aggregated and evaluated using a confidence scoring system based on:
  • Severity of the issue
  • Data volume affected
  • Historical frequency
  • Consistency of detection
Only issues above the configured confidence threshold proceed to remediation.
5. SQL Remediation Suggestions
For high-confidence issues, the workflow automatically generates SQL investigation or remediation queries, such as:
  • ALTER TABLE fixes
  • NULL cleanup queries
  • Outlier review queries
6. Logging & Alerting
Confirmed issues are:
  • Stored in a PostgreSQL audit table
  • Sent as alerts to Slack
7. Baseline Updates
Finally, the workflow updates the data quality baseline table, improving anomaly detection accuracy in future runs.
Setup Instructions
  1. Configure a PostgreSQL credential in n8n.
  2. Replace <target schema name> in the SQL queries with your database schema.
  3. Create the following tables in PostgreSQL:
Audit Table
data_quality_audit
Stores detected data quality issues and remediation suggestions.
Baseline Table
data_quality_baselines
Stores historical statistics used for anomaly detection.
  1. Configure your Slack credential.
  2. Replace the placeholder Slack channel ID in the Send Alert to Team node.
Optional configuration parameters can be modified in the Workflow Configuration node:
  • confidenceThreshold
  • maxNullPercentage
  • outlierStdDevThreshold
  • auditTableName
  • baselineTableName
Use Cases
Database Reliability Monitoring
Detect unexpected schema changes or structural modifications in production databases.
Data Pipeline Validation
Identify anomalies in datasets used by ETL pipelines before they propagate errors downstream.
Analytics Data Quality Monitoring
Prevent reporting inaccuracies caused by missing data or abnormal values.
Production Database Observability
Provide automated alerts when critical database quality issues occur.
Data Governance & Compliance
Maintain a historical audit log of database quality issues and remediation actions.
Requirements
This workflow requires the following services:
  • PostgreSQL Database
  • Slack Workspace
  • n8n
Nodes used:
  • Schedule Trigger
  • Set
  • Postgres
  • Code (Python)
  • Aggregate
  • IF
  • Slack
Key Features
  • Automated database health monitoring
  • Schema drift detection
  • Null explosion detection
  • Statistical anomaly detection
  • Confidence-based issue filtering
  • Automated SQL remediation suggestions
  • Slack alerting
  • Historical baseline learning system
Summary
This workflow provides an automated data quality monitoring system for PostgreSQL. It continuously analyzes schema structure, column statistics, and historical baselines to detect anomalies, generate remediation suggestions, and notify teams in real time.
By automating database quality checks, teams can identify issues early, reduce debugging time, and maintain reliable data pipelines.
