Build an omnichannel OTP verification flow
Created by: Yenire || yenire
Yenire
Last update a day ago
• Receives user identity data from multiple channels (WhatsApp, Telegram, email).
• Generates and stores secure one-time passwords (OTP).
• Validates OTP codes against Postgres records.
• Centralizes user identity across channels.
• Maintains session continuity for onboarding and verification.
Set up steps
• Import the workflow into n8n.
• Configure Postgres or Supabase credentials.
• Download and create the required database tables in Supabase.
• Connect messaging channel credentials.
• Define OTP expiration and validation rules.
• Test using sample user verification scenarios.
