Turn Reddit posts into content ideas with Telegram, Apify, GPT and Sheets
Reddit Content Saver Pipeline
A Telegram-triggered n8n workflow that scrapes Reddit posts, analyzes them with AI, and saves structured content ideas to Google Sheets.
Overview
Send a Reddit post URL to a Telegram bot. The pipeline scrapes the post and comments, runs AI analysis for content insights, deduplicates against previously processed links, and logs everything to Google Sheets — all automatically.
Workflow Diagram
Telegram Trigger └─► Typing Indicator └─► Get Sheets Log (dedup source) └─► Dedup Check ├─► [DUPLICATE] Notify user → stop └─► [NEW] Apify Reddit Scrape └─► Extract Content ├─► [NO CONTENT] Notify user → stop └─► [HAS CONTENT] AI Analysis └─► Save to Sheets └─► Success Reply
Step-by-Step Breakdown
1. Telegram Trigger
Listens for incoming messages on the Reddit Bot Telegram account. The message is expected to contain a Reddit post URL.
2. Typing Indicator
Immediately sends a typing indicator back to the user so they know the bot received the message.
3. Get row(s) in sheet
Fetches all previously processed Reddit URLs from the Google Sheets pipeline log. This is the source of truth for duplicate detection.
Template: https://docs.google.com/spreadsheets/d/1Q0F7Th6cdiqYKJIPwx_G0td59QkRMjNJMxpU3xOVGMU/edit?usp=sharing
4. Dedup Check (Code Node)
Extracts the Reddit URL from the Telegram message using regex, then normalizes both the incoming URL and all stored URLs (strips www., lowercases, removes trailing slashes) before comparing. Sets an is_duplicate flag.
5. Duplicate Branch (If Node)
Condition Action
Duplicate detected Sends Telegram message with original submission date and summary → stops
New link Continues to Apify scraping
6. Reddit Scrape (Apify — Reddit Scraper Lite)
Runs the trudax/reddit-scraper-lite actor against the Reddit URL. Scrapes the post and up to top 10 comments using a residential proxy.
7. Get Dataset Items
Retrieves the results from the completed Apify actor run.
8. Extract & Clean Data (Code Node)
Restructures the raw Apify output — extracts post_title, post_body, and comment_summary_text into a flat object for downstream use.
9. Content Validation (If Node)
Checks whether the scraped post has at least a title, body, or comment text.
Condition Action
Has content Continues to AI analysis
No content Sends "No Content Found" Telegram reply → stops
10. AI: Analyze Content (LangChain + OpenAI)
Passes the post and comments to an OpenAI GPT model. Analyzes the content for ideas, themes, and insights. A Structured Output Parser enforces a consistent JSON response shape.
11. Edit Fields
Maps the AI output into a clean, flat structure ready for Google Sheets ingestion.
12. Save to Google Sheets
Appends a new row to the pipeline log with post metadata, AI analysis results, and the source URL.
13. Success Confirmation
Sends a Telegram message confirming the post has been saved, with a link to the Google Sheet.
Platforms & APIs
Platform Role
Telegram User input (send Reddit URL) and all bot replies
Apify — reddit-scraper-lite Scrapes Reddit post content and comments via residential proxy
OpenAI GPT (via n8n LangChain) AI content analysis and structured output generation
Google Sheets Persistent storage for processed posts and duplicate-detection log
n8n Workflow orchestration
Error States
Scenario Bot Response
URL was previously submitted "You shared this link previously on [date] — [title/summary] — check GSheets [link]"
Scraped post returned no usable content "No Reddit link found. Send me a Reddit post URL and I will analyze it for content ideas."
Credentials Required
Credential Used By
Telegram Bot Token Trigger + all reply nodes
Apify API Key Reddit Scraper actor
OpenAI API Key AI analysis node
Google Sheets OAuth Read (dedup) + Write (save)
