Generate and schedule ASMR Veo 3 reels with GPT-4.1 mini, Shotstack and Postiz
Last update 9 hours ago
1. Generate new idea – Pulls previously used objects from Google Sheet, then uses GPT-4.1-mini to generate a new fruit-shaped glass object not in the list
2. Create Veo prompt – Uses GPT-4.1-mini to generate a hyper-realistic, ASMR-style prompt for the object being gently divided (with safety guidelines to avoid policy triggers)
3. Generate video – Creates an 8-second AI video with Veo 3.0 showing the glass fruit being elegantly separated on a cutting board with ASMR sound layers
4. Convert to vertical – Crops the 16:9 video to 9:16 vertical format using Shotstack
5. Upload to Postiz – Uploads the final video to Postiz (social media scheduler)
6. Schedule across platforms – Detects connected channels (TikTok, YouTube, Instagram) and schedules the video for posting
7. Log for future – The new object is logged to Google Sheets to avoid repetition in the next run
Set up steps
  1. API Keys – Set up accounts for Google Cloud (Veo 3.0 + GCS), OpenAI, Shotstack, and Postiz
  2. Credentials in n8n – Add each API key as a credential in your n8n instance
  3. Configure variables – Update the SET node with your Google Cloud PROJECT_ID and CLIENT_EMAIL
  4. Set up Google Sheet – Create a sheet with a column named object to track previously used objects
  5. Connect Postiz – Ensure your social media channels (TikTok, YouTube, Instagram) are connected in Postiz
  6. Test – Execute the workflow manually or let the schedule trigger run every 8 hours
