AI agent with charts capabilities using OpenAI structured output and Quickchart
Created by: Agent Studio || agentstudio
Agent Studio
Last update 8 months ago
Categories
This workflow is an experiment to integrate charts in AI Agents, using the new Structured Output from OpenAI and Quickchart.io.
  • Users chat with an AI Agent.
  • Anytime the AI Agent considers a chart is needed, it calls a tool to generate a chart
  • OpenAI generates a chart using the Quickchart definition
  • This object is added at the end of a Quickchart.io URL (see documentation)
  • The url is added in the conversation via the AI Agent as markdown.
Set up steps
  • Create an OpenAI API Key
  • Create the OpenAI credentials
  • Use the credentials for the HTTP Request node (as Predefined Credential type)
  • Activate your workflow
  • Start chatting
  • For example, you can ask the AI Agent to generate a chart about the top 5 movies at the box office
  • Start exploring the limits
Shout-out
Quickchart.io is an amazing open source project that provides a free API to test. Go check them out!
Example of chart
