HTTP Request node
+5
AI Agent with charts capabilities using OpenAI Structured Output and Quickchart.io
Published 13 days ago
agentstudio
Agent Studio
Categories
Building Blocks
AI
Template description
This workflow is an experiment to integrate charts in AI Agents, using the new Structured Output from OpenAI and Quickchart.io.
  • Users chat with an AI Agent.
  • Anytime the AI Agent considers a chart is needed, it calls a tool to generate a chart
  • OpenAI generates a chart using the Quickchart definition
  • This object is added at the end of a Quickchart.io URL (see documentation)
  • The url is added in the conversation via the AI Agent as markdown.
Set up steps
  • Create an OpenAI API Key
  • Create the OpenAI credentials
  • Use the credentials for the HTTP Request node (as Predefined Credential type)
  • Activate your workflow
  • Start chatting
  • For example, you can ask the AI Agent to generate a chart about the top 5 movies at the box office
  • Start exploring the limits
Shout-out
Quickchart.io is an amazing open source project that provides a free API to test. Go check them out!
Example of chart
Share Template
Implement complex processes faster with n8n
red icon yellow icon red icon yellow icon
