Narrating over a video using multimodal AI
Created by: Jimleuk || jimleuk
Jimleuk
Last update a month ago
This n8n template takes a video and extracts frames from it which are used with a multimodal LLM to generate a script. The script is then passed to the same multimodal LLM to generate a voiceover clip.
This template was inspired by Processing and narrating a video with GPT's visual capabilities and the TTS API
  • Video is downloaded using the HTTP node.
  • Python code node is used to extract the frames using OpenCV.
  • Loop node is used o batch the frames for the LLM to generate partial scripts.
  • All partial scripts are combined to form the full script which is then sent to OpenAI to generate audio from it.
  • The finished voiceover clip is uploaded to Google Drive.
Sample the finished product here: https://drive.google.com/file/d/1-XCoii0leGB2MffBMPpCZoxboVyeyeIX/view?usp=sharing
Requirements
  • OpenAI for LLM
  • Ideally, a mid-range (16GB RAM) machine for acceptable performance!
Customising this workflow
  • For larger videos, consider splitting into smaller clips for better performance
  • Use a multimodal LLM which supports fully video such as Google's Gemini.
