Weekly dinner meal plan using recipes from Mealie
Created by: Damian Karzon || dkarzon
Damian Karzon
Last update a month ago
This workflow randomly select recipes from a Mealie instance (can use a specific category) and then creates a meal plan in Mealie with those recipes.
How it works:
  • Workflow has a scheduled trigger (set to run weekly on a Friday)
  • Config node sets a few properties to configure the workflow
  • A call to the Mealie API to get the list of recipes
  • The code node holds most of the logic, this will loop through the number of recipes defined in the config node and randomly select a recipe from the list (making sure not to double up any recipes)
  • Once all the recipes are selected it will call the Mealie API to set up the meal plan on the days
  • Add your Mealie API token as a credential and set it on the Http Request nodes
  • Set the relevant schedule trigger to run when you like
  • Update the Config node with the config you want
    • numberOfRecipes - Number of recipes to populate for the meal plan
    • offsetPlanDays - Number of days in the future to start the plan (0 will start it today, 1 tomorrow, etc.)
    • mealieCategoryId - A category id of the category you want to pull in recipes from (default to select from all recipes)
    • mealieBaseUrl - The base url of your Mealie instance
