Intelligent web query and semantic re-ranking flow using Brave and Google Gemini
Created by: Mind-Front || mind-front
Mind-Front
Last update 23 days ago
Workflow Description
This workflow is a powerful, fully automated web query and semantic reranking system that allows users to perform precise, detailed searches, intelligently rank search results and provide high-quality, structured output. Built with AI-powered components, the workflow leverages semantic query generation, result re-ranking, and real-time reporting to deliver actionable insights.
It is particularly well-suited for real-time data retrieval, market research, and any domain requiring automated yet customizable search result processing.
How It Works
  1. Webhook Integration for Input:
    • The workflow begins with a Webhook Node that captures the user's search query as input, enabling seamless integration with other systems.
  2. Step 1: Semantic Query Generation (Powered by "Semantic Search - Query Maker"):
    • Using AI (Google Gemini), the initial query is refined and transformed into a context-aware, expert-level search query.
    • The process ensures that the search engine retrieves the most relevant and precise results.
  3. Step 2: Web Search Execution:
    • A free Brave Search API processes the refined query to fetch search results, ensuring speed and cost efficiency.
  4. Step 3: Semantic Re-Ranking of Results (Powered by "Semantic Search - Result Re-Ranker"):
    • The workflow reranks the search results based on relevance to the original question, prioritizing the most relevant URLs dynamically.
    • Results are passed through AI-powered intelligent reranking to ensure the final output reflects optimal relevance and quality.
  5. Step 4: Structured Output Generation:
    • Results are converted into a well-structured, organized JSON format, ranking the top 10 search results with their titles, links, and descriptions.
    • Missing ranks (if fewer than 10 results) are handled gracefully with placeholders, ensuring consistency.
  6. Step 5: Real-Time Reporting:
    • The reranked search results are sent back to the user or integrated system via the Webhook Node in a JSON-formatted response.
    • Reports are highly structured and ready for downstream processing or consumption.
Key Features
  1. AI-Powered Query Refinement:
    • Transforms basic queries into detailed, expert-level search terms for optimal results.
  2. Dual-Stage Semantic Search:
    • Combines query generation and result reranking for precise, high-relevance outputs.
  3. Top 10 Result Reranking:
    • Dynamically ranks and organizes the top 10 results based on semantic relevance to the query.
  4. Customizable Integration:
    • Fully modifiable for alternative APIs or integrations, such as other search engines or custom ranking logic.
  5. JSON-Formatted Structured Results:
    • Outputs reranked results in a standardized format, ideal for integration into systems requiring machine-readable data.
  6. Webhook-Based Flexibility:
    • Works seamlessly with Webhook inputs for easy deployment in diverse workflows.
  7. Cost-Effective API Usage:
    • Pre-integrated with the free Brave Search API, minimizing operational costs while delivering accurate search results.
Instructions for API Setup
  1. Brave Search API:
  2. AI Integration (Google Gemini):
    • Visit Google AI Studio and generate an API key for semantic query generation and reranking.
  3. Webhook Configuration:
    • Set up the input Webhook to capture search queries and the output Webhook to deliver reranked results.
Why Choose This Workflow?
  • Precision and Relevance: Combines AI-based query generation with advanced reranking for accurate results.
  • Fully Customizable: Easily adapt the workflow to alternative APIs, search engines, or ranking logic.
  • Real-Time Insights: Provides structured, real-time output ready for immediate use.
  • Scalable and Modular: Ideal for businesses, researchers, and data analysts needing a robust, repeatable solution.
Tags
AI Workflow, Semantic Search, Query Refinement, Search Result Reranking, Real-Time Search, Web Search Automation, Google Search, Brave Search, News Search, API Integration, Market Research, Competitive Intelligence, Business Intelligence,Google Gemini, Anthropic Claude, OpenAI, GPT, LLM
