Analyze Reddit posts with AI to identify business opportunities
Created by: Alex Huang || tao
Alex Huang
Last update 22 days ago
Use case
Manually monitoring Reddit for viable business ideas is time-consuming and inconsistent. This workflow automatically analyzes trending Reddit discussions using AI to surface high-potential opportunities, filter irrelevant content, and generate actionable insights - saving entrepreneurs 10+ hours weekly in market research.
What this workflow does
This AI-powered workflow automatically collects trending Reddit discussions, analyzes posts for viable business opportunities using GPT-4, applies smart filters to exclude low-value content, and generates scored opportunity reports with market insights. It identifies unmet customer needs through sentiment analysis, prioritizes high-potential ideas using custom criteria, and outputs structured data to Google Sheets for actionable decision-making.
  • Add Reddit,Google and OpenAI credentials
  • Configure target subreddits in Subreddit node
  • Test workflow by testing workflow
  • Review generated opportunity report in Google Sheets
How to adjust this template
  • Change data sources: Replace Reddit trigger with Twitter/X or Hacker News API
  • Modify criteria: Adjust scoring thresholds in Opportunity Calculator node
  • Add integrations:
    • Create automatic Slack alerts for urgent opportunities
    • Generate draft business plans using AI Document Writer
