Discover & enrich decision-makers with Apollo and human verification
Created by: Uche Madu || uchemadu
Uche Madu
Last update a month ago
🧩 What This Workflow Does
This workflow automates the process of identifying and enriching decision-maker contacts from a list of companies. By integrating with Apollo's APIs and Google Sheets, it streamlines lead generation, ensures data accuracy through human verification, and maintains an organized leads database.
📚 Use Case
Ideal for sales and marketing teams aiming to:
  • Automate the discovery of key decision-makers (e.g., CEOs, CTOs).
  • Enrich contact information with LinkedIn profiles, emails, and phone numbers.
  • Maintain an up-to-date leads database with minimal manual intervention.
  • Receive weekly summaries of newly verified leads.
🧪 Setup
1. Google Sheets Preparation:
  • Use the following pre-configured Google Sheet: Company Decision Maker Discovery Sheet.
  • This spreadsheet includes the necessary tabs and columns: Companies, Contacts, and Contacts (Verified).
  • It also contains a custom onEdit Apps Script function that automatically updates the Status column to Pending whenever the Domain field is modified.
  • To review or modify the script, navigate to Extensions > Apps Script within the Google Sheet.
2. Credentials Setup:
  • Configure the following credentials in your n8n instance:
    • Google Sheets: To read from and write to the spreadsheet.
    • Slack: To send verification prompts and weekly reports.
    • Apollo: To access the Organization Search, Organization Enrichment, People Search, and Bulk People Enrichment APIs.
    • LLM Service (e.g., OpenAI): To generate company summaries and determine departments based on job titles.
3. Workflow Configuration:
  • Import the workflow into your n8n instance.
  • Update the nodes to reference the correct Google Sheet and Slack channel.
  • Ensure that the Apollo and LLM nodes have the appropriate API keys and configurations.
4. Testing the Workflow:
  • Add a new company entry in the Companies tab of the Google Sheet.
  • Verify that the workflow triggers automatically, processes the data, and updates the Contacts and Contacts (Verified) tabs accordingly.
  • Check Slack for any verification prompts and confirm that weekly reports are sent as scheduled.
