Message Buffer System with Redis and GPT-4 for Efficient Processing
Created by: Edisson Garcia || eagarciah707
Edisson Garcia
Last update 2 months ago
Description
This workflow implements a message-batching buffer using Redis for temporary storage and GPT-4 for consolidated response generation. Incoming user messages are collected in a Redis list; once a configurable “inactivity” window elapses or a batch size threshold is reached, all buffered messages are sent to GPT-4 in a single prompt. The system then clears the buffer and returns the consolidated reply.
Key Features
  • Redis-backed buffer to queue incoming messages per user session
  • Dynamic wait time (shorter for long messages, longer for short messages)
  • Batch trigger on inactivity timeout or minimum message count
  • GPT-4 consolidation: merges all buffered messages into one coherent response
Setup Instructions
  1. Map Input
    • Rename node to “Extract Session & Message”
    • Assign context_id and message from webhook or manual trigger
  2. Compute Wait Time
    • Rename node to “Determine Inactivity Timeout”
    • JS Code:
      const wordCount = $json.message.split(' ').filter(w=>w).length;
      return [{ json: {
        context_id: $json.context_id,
        message: $json.message,
        waitSeconds: wordCount < 5 ? 45 : 30
  3. Buffer Message in Redis
    • Push into list buffer_in:{{$json.context_id}}
    • INCR key buffer_count:{{$json.context_id}} with TTL {{$json.waitSeconds + 60}}
  4. Mark Waiting State
    • GET waiting_reply:{{$json.context_id}} → if null, SET it to true with TTL {{$json.waitSeconds}}
    • Rename nodes to “Check Waiting Flag” / “Set Waiting Flag”
  5. Wait for Inactivity
    • Wait node: pause for {{$json.waitSeconds}} seconds
  6. Check Batch Trigger
    • GET keys:
      • last_seen:{{$json.context_id}}
      • buffer_count:{{$json.context_id}}
    • IF both:
      1. buffer_count >= 1
      2. (now – last_seen) >= waitSeconds * 1000
    • Rename node to “Trigger Batch on Inactivity or Count”
  7. Fetch & Consolidate
    • GET entire list buffer_in:{{$json.context_id}}
    • Information Extractor → rename to “Consolidate Messages”
      • System prompt: “You are an expert at merging multiple messages into one clear paragraph without duplicates.”
  8. GPT-4 Chat
    • OpenAI Chat Model (GPT-4)
  9. Cleanup & Respond
    • Delete Redis keys:
      • buffer_in:{{$json.context_id}}
      • waiting_reply:{{$json.context_id}}
    • Return the consolidated reply to the user
Customization Guidance
  • Batch Size Trigger: Add an additional IF to fire when buffer_count reaches your desired batch size.
  • Timeout Policy: Adjust the word-count thresholds or replace with character-count logic.
  • Multi-Channel Support: Change the trigger from a manual test node to any webhook (e.g., chat, SMS, email).
  • Error Handling: Insert a fallback branch to catch Redis timeouts or OpenAI API errors and notify users.
📣 ¡Conéctate con Innovatex!
🔗 Encuentra todos nuestros enlaces en Linktree: innovatexiot.carrd.co
🔗 Conecta conmigo en LinkedIn: Edison Andrés García Herrera
