Message buffer system with Redis for efficient processing
Created by: Edisson Garcia || eagarciah707
Edisson Garcia
Last update 19 days ago
🚀 Message-Batching Buffer Workflow (n8n)
This workflow implements a lightweight message-batching buffer using Redis for temporary storage and a JavaScript consolidation function to merge messages. It collects incoming user messages per session, waits for a configurable inactivity window or batch size threshold, consolidates buffered messages via custom code, then clears the buffer and returns the combined response—all without external LLM calls.
🔑 Key Features
  • Redis-backed buffer queues incoming messages per context_id.
  • Centralized Config Parameters node to adjust thresholds and timeouts in one place.
  • Dynamic wait time based on message length (configurable minWords, waitLong, waitShort).
  • Batch trigger fires on inactivity timeout or when buffer_countbatchThreshold.
  • Zero-cost consolidation via built-in JavaScript Function (consolidate buffer)—no GPT-4 or external API required.
⚙️ Setup Instructions
  1. Extract Session & Message
    • Trigger: When chat message received (webhook) or When clicking ‘Test workflow’ (manual).
    • Map inputs: set variables context_id and message into a Set node named Mock input data (for testing) or a proper mapping node in production.
  2. Config Parameters
    • Add a Set node Config Parameters with:
      minWords: 3         # Word threshold
      waitLong: 10        # Timeout (s) for long messages
      waitShort: 20       # Timeout (s) for short messages
      batchThreshold: 3   # Messages to trigger batch early
    • All downstream nodes reference these JSON values dynamically.
  3. Determine Wait Time
    • Node: get wait seconds (Code)
    • JS code:
      const msg = $json.message || '';
      const wordCount = msg.split(/\s+/).filter(w => w).length;
      const { minWords, waitLong, waitShort } = items[0].json;
      const waitSeconds = wordCount < minWords ? waitShort : waitLong;
      return [{ json: { context_id: $json.context_id, message: msg, waitSeconds } }];
  4. Buffer Message in Redis
    • Buffer messages: LPUSH buffer_in:{{$json.context_id}} with payload {text, timestamp}.
    • Set buffer_count increment: INCR buffer_count:{{$json.context_id}} with TTL {{$json.waitSeconds + 60}}.
    • Set last_seen: record last_seen:{{$json.context_id}} timestamp with same TTL.
  5. Check & Set Waiting Flag
    • Get waiting_reply: if null, Set waiting_reply to true with TTL {{$json.waitSeconds}}; else exit.
  6. Wait for Inactivity
    • WaitSeconds (webhook): pauses for {{$json.waitSeconds}} seconds before batch evaluation.
  7. Check Batch Trigger
    • Get last_seen and Get buffer_count.
    • IF (now - last_seen) ≥ waitSeconds * 1000 OR buffer_count ≥ batchThreshold, proceed; else use Wait node to retry.
  8. Consolidate Buffer
    • consolidate buffer (Code):
      const j = items[0].json;
      const raw = Array.isArray(j.buffer) ? j.buffer : [];
      const buffer = raw.map(x => {
        try { return typeof x === 'string' ? JSON.parse(x) : x;
        } catch { return null; }
      }).filter(Boolean);
      buffer.sort((a, b) => new Date(a.timestamp) - new Date(b.timestamp));
      const texts = buffer.map(e => e.text?.trim()).filter(Boolean);
      const unique = [...new Set(texts)];
      const message = unique.join(' ');
      return [{ json: { context_id: j.context_id, message } }];
  9. Cleanup & Respond
    • Delete Redis keys: buffer_in, buffer_count, waiting_reply, last_seen (for the context_id).
    • Return consolidated message to the user via your chat integration.
🛠 Customization Guidance
  • Adjust thresholds by editing the Config Parameters node.
  • Change concatenation (e.g., line breaks) by modifying the join separator in the consolidation code.
  • Add filters (e.g., ignore empty or system messages) inside the consolidation Function.
  • Monitor performance: for very high volume, consider sharding Redis keys by date or user segments.
© 2025 Innovatex • Automation & AI Solutions • innovatexiot.carrd.coLinkedIn
