Who is it for?
This template is for individuals or businesses who want to sell on LinkedIn and grow their network.
Use case
This workflow can be used to generate leads on LinkedIn, engage them with personalized messages, and qualify them based on their responses.
How this workflow works
- You fill out a form specifying your target audience.
- The system searches for your target audience on LinkedIn.
- It checks if the found profiles are already connections.
- It sends connection requests to those who are not connections.
- After a profile connects back, it sends them a personalized message using their LinkedIn profile data.
How to set it up
- Create a Browserflow account and connect it to your LinkedIn account.
- Enter all your credentials.
- Set a limit on the number of connection requests.
- Start using the workflow through the n8n form or change the trigger as needed.
Browswerflow link - https://browserflow.io
