LinkedIn post automation with AI (GPT-4o) generation & Slack approval
Created by: Amit Mehta || amitswba
Amit Mehta
Last update a month ago
LinkedIn Post Automation with AI Generation (Gpt-4o) & Slack Approval
How it Works
This workflow automates the creation and publishing of LinkedIn posts with AI-generated content and human approval via Slack, using Google Sheets, OpenAI (GPT-4), Slack Interactive Messages, and the LinkedIn API.
Whether you're a social media manager, content creator, or marketing professional, this workflow helps you maintain consistent LinkedIn presence and scale content creation while keeping human oversight — all managed from a simple spreadsheet.
🎯 Use Case
Ideal for:
  • Content Marketers managing multiple LinkedIn accounts
  • Personal Brand Builders maintaining regular posting schedule
  • Agencies handling client social media presence
  • Teams requiring content approval workflows
Setup Instructions
1. Prepare the Spreadsheet
  • File name: Linkedin Post
  • Main sheet structure:
    | ID | Linkedin Post Title | Status | Image URL |
  • Groups sheet structure:
    | GroupIds |
  • Add post topics and set their Status as Pending
2. Configure Google Sheets Nodes
Connect your Google account to:
  • Linkedin-Post-Topic (Trigger node)
  • Update-Status
  • Get-Group-id
3. Add API Credentials
  • OpenAI API Key → for GPT-4 content generation
  • Slack OAuth Token → for approval messages
  • LinkedIn Access Token → for posting content
  • HTTP Header Auth → Bearer token for LinkedIn API
4. Configure Webhooks
  • Set up Slack Interactive Components webhook
  • Point Request URL to your N8N webhook endpoint
  • Enable interactive messages in Slack app
5. Activate the Workflow
Once live, the workflow will:
  1. Monitor spreadsheet for new topics every minute
  2. Generate LinkedIn post using GPT-4
  3. Send to Slack for approval/editing
  4. Upload image to LinkedIn
  5. Publish to profile and groups
  6. Update spreadsheet status to Posted
🔁 Workflow Logic
  1. Trigger: New/updated row with Pending status
  2. Generate: AI creates engaging LinkedIn post
  3. Approve: Slack message for review/edit
  4. Process: Handle approval response
  5. Upload: Register and upload image
  6. Publish: Post to LinkedIn profile & groups
  7. Update: Mark as Posted in sheet
🧩 Node Descriptions
Node Name Description
Linkedin-Post-Topic Monitors spreadsheet for new post topics
Validate-Status Filters only 'Pending' items
Limit Processes one item at a time
Linedin-Post-Creator Generates post content using GPT-4
Format-Content Prepares content for Slack display
Approval-on-Slack Sends interactive approval message
Webhook Receives Slack button responses
Format-Response Extracts edited content from Slack
Set-Final-Message Prepares approved content
Linkedin-User-Detail Fetches LinkedIn user info
Register Image Initiates LinkedIn image upload
Upload Image Uploads image to LinkedIn
Linkedin-post Publishes to personal profile
Get-Group-id Retrieves LinkedIn group IDs
Post-Linkedin-Groups Posts to multiple groups
Update-Status Marks as completed in sheet
🛠️ Customization Tips
  • Adjust AI prompt for brand voice and hashtags
  • Change Slack approver or add multiple reviewers
  • Modify posting schedule with delay nodes
  • Add analytics tracking with additional API calls
  • Filter groups based on specific criteria
  • Include URL shortening for tracking
📒 Suggested Sticky Notes for Workflow
Node/Section Sticky Note Content
Linkedin-Post-Topic "Triggers every minute for new posts in your spreadsheet"
Validate-Status "Filters to process only 'Pending' items - prevents duplicates"
Linedin-Post-Creator "Uses GPT-4 to generate LinkedIn content - customize prompt for your brand voice"
Approval-on-Slack "Sends for human review - edit the Slack user to change approver"
Webhook "Receives approval responses - ensure URL is configured in Slack app"
Register Image "Initiates LinkedIn media upload - requires valid image URL from sheet"
Linkedin-post "Publishes to your profile - update with your LinkedIn credentials"
Post-Linkedin-Groups "Posts to multiple groups - add group IDs in Groups sheet"
Update-Status "Marks as 'Posted' to prevent reprocessing"
💡 AI Prompt Configuration
The workflow uses a sophisticated prompt that:
  • Creates compelling hooks
  • Includes 3-4 informative paragraphs
  • Adds engagement questions
  • Inserts relevant emojis
  • Generates 4-6 hashtags
  • Formats with proper spacing
🔒 Security & Permissions
LinkedIn App Requirements:
  • r_liteprofile - Read profile data
  • r_emailaddress - Access email
  • w_member_social - Post content
  • rw_organization_admin - Group posting
Slack Bot Permissions:
  • chat:write - Send messages
  • im:write - Direct messages
  • users:read - User information
📎 Required Components
Component Purpose
Google Sheet Store post topics and status
LinkedIn App API access for posting
Slack App Interactive approval flow
OpenAI Account GPT-4 content generation
N8N Instance Workflow execution
🧪 Testing Tips
  • Start with one test topic marked as Pending
  • Verify Slack message appears correctly
  • Test both "Approve" and "Edit" buttons
  • Check image upload completes
  • Confirm post appears on LinkedIn
  • Verify status updates to Posted
⚠️ Common Issues & Solutions
LinkedIn API Errors:
  • Token expiration → Refresh access token
  • Rate limits → Add delays between posts
  • Group restrictions → Check posting permissions
Slack Integration:
  • Missing responses → Verify webhook URL
  • Button not working → Check interactive components
  • User not found → Confirm Slack user ID
Image Upload Failures:
  • Invalid URL → Validate image accessibility
  • Size limits → Compress images under 10MB
  • Format issues → Use JPEG or PNG only
📊 Workflow Benefits
  • Time Savings: 80% reduction in content publishing time
  • Consistency: Regular posting schedule maintained
  • Quality Control: Human review ensures brand standards
  • Scalability: Handle multiple accounts and groups
  • Flexibility: Easy to modify and extend
📎 Required Files
File Name Purpose
Linkedin Post Google Sheet to hold post topics and status
🏷 Suggested Tags & Categories
  • #LinkedIn
  • #AI
  • #ContentAutomation
  • #SocialMedia
  • #Slack
  • #GPT4
  • #Marketing
  • #WorkflowAutomation
