AI-Powered Employee Database Management via Telegram using OpenAI and Airtable
Created by: Billy Christi || billy
Billy Christi
Last update 22 days ago
Categories
Who is this for?
This workflow is perfect for:
  • HR professionals seeking to automate employee and department management
  • Startups and SMBs that want an AI-powered HR assistant on Telegram
  • Internal operations teams that want to simplify onboarding and employee data tracking
What problem is this workflow solving?
Managing employee databases manually is error-prone and inefficient—especially for growing teams. This workflow solves that by:
  • Enabling natural language-based HR operations directly through Telegram
  • Automating the creation, retrieval, and deletion of employee records in Airtable
  • Dynamically managing related data such as departments and job titles
  • Handling data consistency and linking across relational tables automatically
  • Providing a conversational interface backed by OpenAI for smart decision-making
What this workflow does
Using Telegram as the interface and Airtable as the backend database, this intelligent HR workflow allows users to:
  1. Chat in natural language (e.g. “Show me all employees” or “Create employee: Sarah, Marketing…”)
  2. Interpret and route requests via an AI Agent that acts as the orchestrator
  3. Query employee, department, and job title data from Airtable
  4. Create or update records as needed:
    • Add new departments and job titles automatically if they don’t exist
    • Create new employees and link them to the correct department and job title
  5. Delete employees based on ID
  6. Respond directly in Telegram, providing user-friendly feedback
  1. View & Copy the Airtable base here:
    👉 Employee Database Management – Airtable Base Template
  2. Telegram Bot: Set up a Telegram bot and connect it to the Telegram Trigger node
  3. Airtable: Prepare three Airtable tables:
    • Employees with links to Departments and Job Titles
    • Departments with Name & Description
    • Job Titles with Title & Description
  4. Connect your Airtable API key and base/table IDs into the appropriate Airtable nodes
  5. Add your OpenAI API key to the AI Agent nodes
  6. Deploy both workflows: the main chatbot workflow and the employee creation sub-workflow
  7. Test with sample messages like:
    • “Create employee: John Doe, [email protected], Engineering, Software Engineer”
    • “Remove employee ID rec123xyz”
How to customize this workflow to your needs
  • Switch databases: Replace Airtable with Notion, PostgreSQL, or Google Sheets if desired
  • Enhance security: Add authentication and validation before allowing deletion
  • Add approval flows: Integrate Telegram button-based approvals for sensitive actions
  • Multi-language support: Expand system prompts to support multiple languages
  • Add logging: Store every user action in a log table for auditability
  • Expand capabilities: Integrate payroll, time tracking, or Slack notifications
Extra Tips
  • This is a two-workflow setup. Make sure the sub-workflow is deployed and accessible from the main agent.
  • Use Simple Memory per chat ID to preserve context across user queries.
  • You can expand the orchestration logic by adding more tools to the main agent—such as “Get active employees only” or “List employees by job title.”
Contact me for consulting and support:
📧 [email protected]
