Run Complete Technical SEO Audits with GPT-4o AI Analysis & Multi-format Reporting
Last update 6 hours ago
Categories
Instantly map all internal URLs, perform AI-powered (ChatGPT) analysis, and deliver results in HTML via webhook, Google Sheets, or email.
All from your own n8n instance!
Why this workflow?
Forget expensive tools: Run deep, visual audits replacing Screaming Frog or Ahrefs.
Real URL mapping: Reads the sitemap, filters only internal URLs, and analyzes each one individually.
AI-powered analysis: ChatGPT detects critical issues, recommendations, and best practices on every page.
Error handling: The workflow includes robust error handling and guides you on what to do in each case.
Client-ready results: Receive a professional HTML report, an email summary, or push it to Google Sheets for team collaboration.
Automate by webhook or manually: Use it in backend integrations, or trigger with a button.
🧠 What does the workflow do?
Automatically detects the sitemap (robots.txt → sitemap.xml).
Filters only internal URLs (ignores assets, images, scripts, etc).
Fetches the full HTML content of each URL.
Uses ChatGPT (GPT-4o-mini) for professional diagnostics (meta tags, headings, hreflang, Open Graph, links, duplicate content, etc).
Groups results (critical issues, recommendations, best practices) and presents them as:
Professional HTML report (ready to send/share)
Google Sheets (collaborative structure)
Webhook or HTML email (for automation)
🛠️ Technologies/APIs Used
n8n (self-hosted or cloud instance required)
ChatGPT API (required, approx. cost: €0.01 per 20 URLs analyzed)
Google Drive/Sheets API (only for Google Sheets output)
Email SMTP/Gmail (for notifications)
⚡ Who should use it?
SEOs and agencies needing technical reports in minutes
Freelancers automating client SEO audits
Web developers and growth hackers
Website owners/businesses with multiple sites
🎯 Problems solved
Slow, manual SEO auditing
Dependence on expensive SaaS
Lack of full-site coverage: every URL is checked with actionable recommendations
Fast, visual delivery to clients (HTML “copy-paste” report and/or collaborative sheet)
📝 Quick Setup
Import the .json into your n8n.
Add your credentials:
OpenAI (ChatGPT) API Key
Google account (only for Google Sheets output)
Run manually or via webhook (you can pass the URL as a parameter).
View the results in the generated HTML, Google Sheets, or your email.
💡 Details & Tips
Just enter the domain (example.com) without https:// and no trailing slash.
If any error occurs (unusual sitemap, robots blocked, etc), the error messages are explained.
You can change the analysis language (default is Spanish).
100% customizable and extendable for other outputs (Notion, Slack, etc).
📦 What’s included?
n8n workflow file (SEO n8n.json)
Guide (README)
Direct support: [email protected]
