TalentFlow AI – Instantly evaluate applicant's GitHub, LinkedIn, using AI
Created by: Roshan Ramani || rawsun007
Roshan Ramani
Last update a month ago
AI-Powered Job Application Screening Workflow
Who Is This For?
This template is ideal for:
  • HR teams
  • Recruiters
  • Hiring managers
Who want to automate the screening of job applicants. If you collect candidate data via JotForm and want an AI‑powered, multi‑source evaluation—without manual copy‑paste—this workflow is for you.
What Problem Does This Solve?
Manually reviewing:
  • LinkedIn profiles
  • GitHub repos
  • LeetCode stats
  • Resume PDFs
Is time‑consuming and error‑prone. This workflow:
  1. Centralizes all candidate data
  2. Scores each dimension against specific job requirements
  3. Appends results to Google Sheets
  4. Helps make data‑driven hiring decisions faster
What This Workflow Does
1. Trigger on New JotForm Submission
Captures candidate name, email, social URLs, resume link, and job description
(Pro Tip: Add hidden field in JotForm to pass job requirements)
2. Extract & Normalize Usernames
Parses LinkedIn, GitHub, and LeetCode handles
3. Scrape & Format Data
  • LinkedIn → profile & latest posts via ScrapingDog & Apify
  • GitHub → profile, repos, and contribution metrics via GitHub GraphQL
  • LeetCode → submission stats & rankings via LeetCode GraphQL
  • Resume → converts PDF to text with PDF.co
4. AI‑Powered Evaluation
Uses LangChain agents on OpenRouter to:
  • Generate fit scores (1–10) based on job description
  • Provide justifications for each source
  • Analyze candidate suitability against specific role requirements
5. Merge & Append
Consolidates scores and feedback → writes new row to Google Sheets with hyperlinks and totals
JotForm Configuration
  1. Create your job application form
  2. Add Hidden Field:
    • Name: job_description
    • Value: [Paste full job description here]
      (This enables AI to evaluate candidates against specific role requirements)
  3. Create fields matching the workflow requirements
Required Credentials/Variables
  • JotForm API key
  • SCRAPINGDOG_API_KEY & Apify token
  • GitHub personal access token (read‑only)
  • PDF.co API key
  • OpenRouter API key
Configuration Steps
  1. Google Sheets
    • Create or select spreadsheet
    • Grant n8n access
  2. Node Organization
    • All nodes renamed for clarity
    • Sticky notes explain prerequisites
How to Customize
1. Job-Specific Evaluation
  • Include hidden job_description field in JotForm
  • AI will automatically analyze candidates against these requirements
2. Add/Edit Fields
Use Edit Fields node to map your form questions
3. Adjust Scoring
Tweak agent prompts:
  • linkedin evaluation
  • github evaluation
  • etc.
4. Extend Sources
Insert new branches (e.g., Stack Overflow) by following existing patterns
Result
Transforms raw candidate submissions into actionable insights—evaluating applicants against specific job requirements and reducing screening time from hours to minutes with consistent, unbiased evaluations.
