Auto-generate problem-focused blog posts for Shopify products with AI
Last update 23 days ago
This workflow contains community nodes that are only compatible with the self-hosted version of n8n.
AI Blog Automation for Shopify is a n8n workflow that automatically transforms your Shopify products into engaging, problem-focused blog posts.
Say goodbye to spending 5+ hours per article – this workflow generates SEO-optimized content that addresses customer pain points, not just product features.
🎯 Who is this for?
  • E-commerce store owners wanting consistent content marketing without the time investment.
  • Dropshipping entrepreneurs with frequent product launches needing automated blog content.
  • Shopify merchants who know blogging drives traffic but lack writing resources.
  • Content marketers seeking scalable, cost-effective blog automation.
🚨 Problem Solved
Creating quality blog content is time-consuming and expensive. Most store owners either skip blogging entirely or burn out after a few posts. This workflow solves it by:
  • Automatically generating problem-first content (not salesy product descriptions).
  • Creating stunning AI-generated hero images for each post.
  • Publishing directly to your Shopify blog with proper SEO formatting.
  • Costing only $0.05-0.15 per post vs. $200+ for professional writers.
⚙️ What This Workflow Does
Feature Description
Triggers - Manual execution for existing products<br>- Automatic trigger when new products are created
Analyzes Products Uses LangChain + OpenAI to:<br>- Identify core problems the product solves<br>- Analyze customer pain points<br>- Generate problem-focused angles
Creates Content GPT-4o-mini generates 1000-1500 word articles:<br>- Problem-first approach (not product-first)<br>- SEO-optimized structure<br>- Natural product integration<br>- Soft call-to-actions
Generates Images DALL-E 3 creates blog hero images:<br>- Matches blog theme (not just product)<br>- Brand-consistent styling<br>- Mobile-optimized dimensions
Hosts Images Uploads to ImgBB (free CDN):<br>- No expiration<br>- Fast global delivery<br>- Direct URL integration
Publishes Posts directly to Shopify blog:<br>- Proper HTML formatting<br>- SEO meta descriptions<br>- Relevant tags<br>- Mobile-responsive images
🚀 Setup Instructions
🔐 Credentials Needed
  • Shopify Access Token API (with read_products, write_content, read_content scopes)
  • OpenAI API (for content + image generation)
  • ImgBB API (free image hosting)
🔧 Shopify Configuration
  • Create private app in Shopify admin
  • Enable required API scopes:
    • read_products - Read product data
    • write_content - Create blog posts
    • read_content - Access blog configuration
  • Copy access token (starts with shpat_)
🧩 Node Setup
  • Manual Trigger — For on-demand execution
  • Shopify Trigger — Auto-runs on product creation
  • Shopify Node — Fetches product data
  • LangChain + OpenAI — Generates problem-focused content
  • Structured Output Parser — Formats AI response
  • HTTP Request — Retrieves blog configuration
  • DALL-E Node — Creates hero images
  • ImgBB Upload — Hosts images on free CDN
  • GraphQL Mutation — Publishes to Shopify blog
🛠️ Customization Tips
Feature How to Customize
Content Length Adjust word count in AI Content Generator prompt
Image Style Modify DALL-E prompt for brand colors/aesthetics
Author Name Change author field in Publish Blog Article node
Blog Selection Update blog ID to target specific Shopify blog
Publishing Set isPublished: false to save as drafts
Brand Voice Customize tone and style in content prompts
📦 Pre-Requirements
  • n8n instance (Cloud or self-hosted) (Cloud/Self-hosted)
  • Install: @n8n/n8n-nodes-langchain
  • Shopify private app with proper scopes
  • OpenAI account with billing enabled
  • ImgBB account (free)
🔧 Nodes Used
  • Manual Trigger
  • Shopify Trigger
  • Shopify
  • LangChain LLM
  • OpenAI Chat Model
  • HTTP Request
  • OpenAI (DALL-E)
  • Wait
✅ Test the Workflow
  1. Import workflow and configure all credentials.
  2. Update store URLs and API tokens.
  3. Run manually or add a new product to trigger automatically.
  4. Check your Shopify blog for the new problem-focused post!
💰 Expected Results
  • Time Saved: 5+ hours per blog post
  • Cost: $0.10-0.20 per post (vs. $200+ for writers)
  • Traffic: 40-60% increase within 3 months (typical)
  • Content Quality: Problem-focused, not salesy
Made by: Khaisa Studio
Tags: shopify, blog, automation, ai, content-marketing, seo
Category: E-commerce Automation, Content Marketing
Need customization? contact me on LinkedIn or Web
