AI-powered accounting reports from Sabre EDI with GPT-4 and Pinecone RAG
Created by: Mohan Gopal || mohan
Mohan Gopal
Last update 15 days ago
This workflow automates the process of reading EDI files generated by Sabre, parsing them using an AI Agent, and producing structured accounting reports like:
📌 Accounts Receivable (AR) Summary
📌 Tax and Surcharges Report
It also uses Retrieval-Augmented Generation (RAG) to vectorize the Sabre Interface User Record (IUR)—a 154-page technical document—so that the AI agent can reference it when clarification is required while generating reports.
⚙️ Tools & Integrations Used
Component:Tool/Service:Purpose:Workflow Engine:n8n:Automation & orchestration
LLM Model:OpenAI GPT-4 / Chat Model:Natural language understanding and parsing
Embeddings Model:OpenAI Embeddings:Convert text into semantic vector format
Vector Database:Pinecone:Store and retrieve document chunks semantically
Storage:Google Drive:Source of raw EDI text files and PDF documentation
DataLoader + Splitter:n8n Node + Recursive Splitter:Loads and prepares documents for embedding
AI Agents:n8n AI Agent Node:Runs context-aware prompts and parses reports
🧱 Workflow Breakdown
🧠 1. Vectorizing the Sabre IUR Document (RAG Setup)
📘 Objective: Enable the AI Agent to refer to the IUR document (154 pages) for detailed explanations of EDI terms, formats, and rules.
Flow Steps:
Google Drive Search + Download – Find and pull the IUR PDF file.
Default Data Loader – Load the file and preprocess it for semantic splitting.
Recursive Character Splitter – Break down large pages into meaningful chunks.
OpenAI Embeddings – Vectorize each chunk.
Pinecone Vector Store – Save into a Pinecone namespace for future retrieval.
✅ Result: The IUR is now searchable via semantic queries from the AI Agent.
📁 2. Reading and Extracting Data from EDI Files
📘 Objective: Parse raw EDI files for financial records and summaries.
Flow Steps:
Trigger – Manual or scheduled execution of the workflow.
Google Drive Search – Finds all new .edi or .txt files.
Download File Contents – Loads content of each file into memory.
Extract from File – Raw text extraction.
📊 3. Report Generation Using AI Agents
📘 Objective: AI Agents parse the extracted data to generate structured accounting reports.
a. Accounts Receivable Report Agent
The extracted text is passed to an AI Agent.
Model is connected to:
OpenAI Chat Model (LLM)
Pinecone Vector DB (IUR reference)
Outputs a structured AR Summary Report.
b. Tax and Surcharges Report Agent
Same steps as above.
Prompts adjusted to extract tax, fees, surcharges, and amounts.
✅ Output Format: Can be mapped to columns and inserted into a Google Sheet or exported as a CSV/JSON.
📑 Sample Reports You Can Build
Already implemented:
✅ Accounts Receivable (AR) Summary Report
✅ Tax and Surcharges Report
Can be extended to:
3. Accounts Payable (AP)
4. Passenger Revenue
5. Daily Sales
6. Commission Report
7. Net Profit Margin (if supplier cost + commission is available)
💡 Key Advantages
✅ No-code automation with n8n
✅ Semantic reasoning using AI + Vector DB (RAG)
✅ Can work with various Sabre outputs without manual parsing
✅ Modular: Easy to add new report types
✅ Cloud-integrated (Drive, Pinecone, OpenAI)
🧪 Potential Improvements
Area Suggestions
Testing Add a “Preview” step to validate extracted data before writing
Scalability Batch mode + Google Sheet batching for multiple reports
Audit Trail Log every file name, timestamp, report type in a Google Sheet
Notification Send Slack/Email when a new report is generated
Multi-model support Add Claude/Gemini fallback if OpenAI usage limit is hit
