Generate realistic sound effects with CassetteAI and save to Google Drive
Created by: Davide Boizza || n3witalia
Davide Boizza
Last update 25 days ago
The Sound Effects Generator is an automated workflow that allows users to create realistic sound effects using AI and save them directly to Google Drive. It generates high-quality sound effects (up to 30 seconds long) based on user prompts.
How It Works:
  1. User Input via Web Form
    A form is presented to the user asking for:
    • A prompt describing the sound (e.g. "waves crashing", "laser blast").
    • A duration in seconds (up to 30 seconds).
  2. API Request to Generate Audio
    The input is sent to CassetteAI via a POST request using API with proper authentication.
  3. Status Polling
    The workflow waits for 10 seconds and then checks the status of the request.
  4. Conditional Flow
    • If the audio generation is complete (COMPLETED), it proceeds to fetch the audio file URL.
    • If not, it waits and retries.
  5. Download & Save
    • The audio file is downloaded from the URL.
    • It is automatically uploaded to a specific folder in the user’s Google Drive, with a timestamped filename.
Key Advantages
  • Fast & Efficient: Generates up to 30 seconds of audio in just 1 second of processing time.
  • No Coding Required: Entire flow can be triggered via a simple form interface.
  • Automated Storage: Files are automatically saved to a preconfigured Google Drive folder.
  • Scalable: Can be reused for multiple projects by simply changing the input prompts.
  • Secure: Uses secure API key-based authentication for interaction with Fal.run and Google Drive.
  • Customizable: Easy to adapt or extend—for example, sending download links via email or Telegram.
How It Works
  1. Form Submission: The workflow starts with a form where users input a prompt and the desired duration (max 30 seconds) for the sound effect.
  2. Audio Creation: The submitted data is sent to the CassetteAI Sound Effects Generator API via an HTTP request, which initiates the sound effect generation process.
  3. Status Check: The workflow periodically checks the status of the request. If the status is "COMPLETED," it proceeds to fetch the audio file.
  4. Audio Retrieval: The generated audio file is downloaded from the provided URL and uploaded to a specified Google Drive folder, with a timestamped filename for organization.
Set Up Steps
  1. API Key Configuration:
    • Create an account on fal.ai and obtain an API key.
    • In the "Create audio" node, set the "Header Auth" with:
      • Name: Authorization
      • Value: Key YOURAPIKEY (replace YOURAPIKEY with your actual API key).
  2. Google Drive Integration:
    • Ensure the Google Drive node is configured with the correct OAuth2 credentials and folder ID.
    • Adjust the folder ID in the "Upload Audio" node if a different destination is preferred.
Need help customizing?
Contact me for consulting and support or add me on Linkedin.
