Pinterest keyword-based content scraper with AI agent & BrightData automation
Created by: Shiv Gupta || shivgupta
Shiv Gupta
Last update 15 days ago
Pinterest Keyword-Based Content Scraper with AI Agent & BrightData Automation
Overview
This n8n workflow automates Pinterest content scraping based on user-provided keywords using BrightData's API and Claude Sonnet 4 AI agent. The system intelligently processes keywords, initiates scraping jobs, monitors progress, and formats the extracted data into structured outputs.
Architecture Components
🧠 AI-Powered Controller
  • Claude Sonnet 4 Model: Processes and understands keywords before initiating scrape
  • AI Agent: Acts as the intelligent controller coordinating all scraping steps
📥 Data Input
  • Form Trigger: User-friendly keyword input interface
  • Keywords Field: Required input field for Pinterest search terms
🚀 Scraping Pipeline
  1. Launch Scraping Job: Sends keywords to BrightData API
  2. Status Monitoring: Continuously checks scraping progress
  3. Data Retrieval: Downloads completed scraped content
  4. Data Processing: Formats and structures the raw data
  5. Storage: Saves results to Google Sheets
Workflow Nodes
1. Pinterest Keyword Input
  • Type: Form Trigger
  • Purpose: Entry point for user keyword submission
  • Configuration:
    • Form title: "Pinterest"
    • Required field: "Keywords"
2. Anthropic Chat Model
  • Type: Language Model (Claude Sonnet 4)
  • Model: claude-sonnet-4-20250514
  • Purpose: AI-powered keyword processing and workflow orchestration
3. Keyword-based Scraping Agent
  • Type: AI Agent
  • Purpose: Orchestrates the entire scraping process
  • Instructions:
    • Initiates Pinterest scraping with provided keywords
    • Monitors scraping status until completion
    • Downloads final scraped data
    • Presents raw scraped data as output
4. BrightData Pinterest Scraping
  • Type: HTTP Request Tool
  • Method: POST
  • Endpoint: https://api.brightdata.com/datasets/v3/trigger
  • Parameters:
    • dataset_id: gd_lk0sjs4d21kdr7cnlv
    • include_errors: true
    • type: discover_new
    • discover_by: keyword
    • limit_per_input: 2
  • Purpose: Creates new scraping snapshot based on keywords
5. Check Scraping Status
  • Method: GET
  • Endpoint: https://api.brightdata.com/datasets/v3/progress/{snapshot_id}
  • Purpose: Monitors scraping job progress
  • Returns: Status values like "running" or "ready"
6. Fetch Pinterest Snapshot Data
  • Method: GET
  • Endpoint: https://api.brightdata.com/datasets/v3/snapshot/{snapshot_id}
  • Purpose: Downloads completed scraped data
  • Trigger: Executes when status is "ready"
7. Format & Extract Pinterest Content
  • Type: Code Node (JavaScript)
  • Purpose: Parses and structures raw scraped data
  • Extracted Fields:
    • URL
    • Post ID
    • Title
    • Content
    • Date Posted
    • User
    • Likes & Comments
    • Media
    • Image URL
    • Categories
    • Hashtags
8. Save Pinterest Data to Google Sheets
  • Type: Google Sheets Node
  • Operation: Append
  • Mapped Columns:
    • Post URL
    • Title
    • Content
    • Image URL
9. Wait for 1 Minute (Disabled)
  • Type: Code Tool
  • Purpose: Adds delay between status checks (currently disabled)
  • Duration: 60 seconds
Setup Requirements
Required Credentials
  1. Anthropic API
    • Credential ID: ANTHROPIC_CREDENTIAL_ID
    • Required for Claude Sonnet 4 access
  2. BrightData API
    • API Key: BRIGHT_DATA_API_KEY
    • Required for Pinterest scraping service
  3. Google Sheets OAuth2
    • Credential ID: GOOGLE_SHEETS_CREDENTIAL_ID
    • Required for data storage
Configuration Placeholders
Replace the following placeholders with actual values:
  • WEBHOOK_ID_PLACEHOLDER: Form trigger webhook ID
  • GOOGLE_SHEET_ID_PLACEHOLDER: Target Google Sheets document ID
  • WORKFLOW_VERSION_ID: n8n workflow version
  • INSTANCE_ID_PLACEHOLDER: n8n instance identifier
  • WORKFLOW_ID_PLACEHOLDER: Unique workflow identifier
Data Flow
User Input (Keywords)
AI Agent Processing (Claude)
BrightData Scraping Job Creation
Status Monitoring Loop
Data Retrieval (when ready)
Content Formatting & Extraction
Google Sheets Storage
Output Data Structure
Each scraped Pinterest pin contains:
  • URL: Direct link to Pinterest pin
  • Post ID: Unique Pinterest identifier
  • Title: Pin title/heading
  • Content: Pin description text
  • Date Posted: Publication timestamp
  • User: Pinterest username
  • Engagement: Likes and comments count
  • Media: Media type information
  • Image URL: Direct image link
  • Categories: Pin categorization tags
  • Hashtags: Associated hashtags
  • Comments: User comments text
Usage Instructions
  1. Initial Setup:
    • Configure all required API credentials
    • Replace placeholder values with actual IDs
    • Create target Google Sheets document
  2. Running the Workflow:
    • Access the form trigger URL
    • Enter desired Pinterest keywords
    • Submit the form to initiate scraping
  3. Monitoring Progress:
    • The AI agent will automatically handle status monitoring
    • No manual intervention required during scraping
  4. Accessing Results:
    • Structured data will be automatically saved to Google Sheets
    • Each run appends new data to existing sheet
Technical Notes
  • Rate Limiting: BrightData API has built-in rate limiting
  • Data Limits: Current configuration limits 2 pins per keyword
  • Status Polling: Automatic status checking until completion
  • Error Handling: Includes error capture in scraping requests
  • Async Processing: Supports long-running scraping jobs
Customization Options
  • Adjust Data Limits: Modify limit_per_input parameter
  • Enable Wait Timer: Activate the disabled wait node for longer jobs
  • Custom Data Fields: Modify the formatting code for additional fields
  • Alternative Storage: Replace Google Sheets with other storage options
Sample Google Sheets Template
Create a copy of the sample sheet structure:
https://docs.google.com/spreadsheets/d/SAMPLE_SHEET_ID/edit
Required columns:
  • Post URL
  • Title
  • Content
  • Image URL
Troubleshooting
  • Authentication Errors: Verify all API credentials are correctly configured
  • Scraping Failures: Check BrightData API status and rate limits
  • Data Formatting Issues: Review the JavaScript formatting code for parsing errors
  • Google Sheets Errors: Ensure proper OAuth2 permissions and sheet access
For any questions or support, please contact: Email or
fill out this form
