AI-powered one-click virtual fitting room for WooCommerce, Shopify, Prestashop
Created by: Davide Boizza || n3witalia
Davide Boizza
Last update 25 days ago
This low-code automation enables all eCommerce store visitors to upload a photo of themselves and virtually “try on” a garment in just a few clicks.
With this workflow, WooCommerce, Prestashop, Shopify and more merchants can offer a cutting-edge “virtual try-on” feature with minimal development effort, enhancing customer engagement and reducing product returns.
Key Advantages
  • Zero-Coding, Visual Setup
    Build end-to-end e-commerce features with drag-and-drop nodes instead of custom backend code.
  • Asynchronous, Scalable Processing
    Non-blocking “Wait” + “If” loop handles multi-second AI jobs gracefully, freeing up the workflow for other tasks.
  • Dynamic Inputs & URLs
    Query strings (e.g. ?Product=IMAGE_URL) allow you to embed the form on any product page and pass the garment image on the fly.
  • Seamless User Experience
    Instant pop-up within your storefront and automatic redirect to the generated mock-up keeps shoppers engaged without page reloads.
  • Easy Credential Management
    API keys, FTP credentials, and webhook IDs are all stored securely in n8n’s credential manager.
How It Works
  1. Form Submission:
    • A user submits a form with their name, an image of themselves ("Me"), and a hidden product image URL ("Product").
    • The form is triggered via the On form submission node, which collects the input data.
  2. Image Upload:
    • The uploaded image ("Me") is sent to an FTP server for temporary storage using the FTP node. The filename includes a timestamp to ensure uniqueness.
  3. Virtual Try-on Request:
    • The Create Image node sends a POST request to the Fal.run API, providing:
      • The uploaded human image URL (from FTP).
      • The product image URL (from the hidden form field).
    • This generates a virtual try-on result.
  4. Result Processing:
    • The workflow checks the status of the image generation (Get status node) in a loop (with a 10-second wait between checks) until it is marked as "COMPLETED."
    • Once ready, the final image URL is fetched (Get Url image node) and displayed to the user via a redirect (Form node).
  5. User Experience:
    • The user is redirected to the generated try-on image, completing the process.
Set Up Steps
  1. API Key Setup:
    • Create an account and obtain an API key.
    • Configure the Create Image node with HTTP Header Authentication:
      • Name: Authorization
      • Value: Key YOURAPIKEY
  2. FTP/S3 Configuration:
    • Set up an FTP server or S3 bucket to temporarily store uploaded user images.
    • Configure the FTP node with your FTP credentials and storage path.
  3. Ecommerce Integration:
    • On your WooCommerce site, add a "Try On" button that opens the form in a pop-up.
    • Dynamically pass the product image URL as a query parameter:
      • Example: https://URL_N8N/form/ca1c314d-46c6-4eeb-b6a5-359XXXXXX?Product=IMAGE_URL
  4. Testing:
    • Verify the workflow by submitting a test form and ensuring the virtual try-on image is generated and displayed correctly.
Need help customizing?
Contact me for consulting and support or add me on Linkedin.
