Aws cost & usage report management for AI agents
Created by: David Ashby || cfomodz
David Ashby
Last update 18 days ago
Categories
Complete MCP server exposing 4 AWS Cost and Usage Report Service API operations to AI agents.
⚡ Quick Setup
Need help? Want access to more workflows and even live Q&A sessions with a top verified n8n creator.. All 100% free?
Join the community
  1. Import this workflow into your n8n instance
  2. Credentials Add AWS Cost and Usage Report Service credentials
  3. Activate the workflow to start your MCP server
  4. Copy the webhook URL from the MCP trigger node
  5. Connect AI agents using the MCP URL
🔧 How it Works
This workflow converts the AWS Cost and Usage Report Service API into an MCP-compatible interface for AI agents.
MCP Trigger: Serves as your server endpoint for AI agent requests
HTTP Request Nodes: Handle API calls to http://cur.{region}.amazonaws.com
AI Expressions: Automatically populate parameters via $fromAI() placeholders
Native Integration: Returns responses directly to the AI agent
📋 Available Operations (4 total)
🔧 #X-Amz-Target=Awsorigamiservicegatewayservice.Deletereportdefinition (1 endpoints)
POST /#X-Amz-Target=AWSOrigamiServiceGatewayService.DeleteReportDefinition: Deletes the specified report.
🔧 #X-Amz-Target=Awsorigamiservicegatewayservice.Describereportdefinitions (1 endpoints)
POST /#X-Amz-Target=AWSOrigamiServiceGatewayService.DescribeReportDefinitions: Lists the AWS Cost and Usage reports available to this account.
🔧 #X-Amz-Target=Awsorigamiservicegatewayservice.Modifyreportdefinition (1 endpoints)
POST /#X-Amz-Target=AWSOrigamiServiceGatewayService.ModifyReportDefinition: Allows you to programatically update your report preferences.
🔧 #X-Amz-Target=Awsorigamiservicegatewayservice.Putreportdefinition (1 endpoints)
POST /#X-Amz-Target=AWSOrigamiServiceGatewayService.PutReportDefinition: Creates a new report using the description that you provide.
🤖 AI Integration
Parameter Handling: AI agents automatically provide values for:
• Path parameters and identifiers
• Query parameters and filters
• Request body data
• Headers and authentication
Response Format: Native AWS Cost and Usage Report Service API responses with full data structure
Error Handling: Built-in n8n HTTP request error management
💡 Usage Examples
Connect this MCP server to any AI agent or workflow:
Claude Desktop: Add MCP server URL to configuration
Cursor: Add MCP server SSE URL to configuration
Custom AI Apps: Use MCP URL as tool endpoint
API Integration: Direct HTTP calls to MCP endpoints
✨ Benefits
Zero Setup: No parameter mapping or configuration needed
AI-Ready: Built-in $fromAI() expressions for all parameters
Production Ready: Native n8n HTTP request handling and logging
Extensible: Easily modify or add custom logic
🆓 Free for community use! Ready to deploy in under 2 minutes.
